ONTAP Hardware
Does X374A (960GB SSD) Support Flash Pool
nachin
Dear all,
I am not sure if this is appropriate to discuss this topic here.
I checked HWU and found X374A. It is a 3.5" 960GB SSD supported as of ONTAP 9.0 nd later. Since it is of 3.5" form factor, I should choose DS4246, DS412C, FAS2520, and FAS2554 as its carrier. However in Synergy Portal I cannot find X374A even if I chose there carriers. I cannot find anything about X374A on google, either. Why is X374A so secret?
1 REPLY 1
georgevj
I guess it snot secret, its just new. You will see more when the synergy tool (and the others)  is updated with new info.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
