ONTAP Hardware
Double FC-p2p on FAS2040
mlorente1
Hello, I intend to mount the following structure, and the truth is that I wish to advise me on their viability.
We have a FAS2040 with 12 local storage disks
to serve NFS from the ethernet ports, so the 2 FC ports are free. We intend to connect two servers, each of them to a FC port the FAS by a direct link free FC-P2P, thus intend to access local disks in SAN mode, while on the ethernet port would agree to NFS storage.
Is my approach correct?
thanks
2 REPLIES 2
radek_kubka
Hi,
Direct FCP is supported - or at least it used to be.
I can't find the pdf though, which specified all supported combinations: fc_iscsi_config_guide.pdf
(it used to be on NOW, but my old link doesn't work any longer)
Regards,
Radek
mlorente1
Thanks for your response. So, for the time being the structure is rigth.
