ONTAP Hardware
FAS 2720 Two node Switchless Cluster - Interconnect
Ragesh
Hello
We have FAS 2720 box with Base T ports,  i would like to use Base T e0c/e0d/eoe/e0f ports for cluster interconnect ,  to use e0a/e0b SFP+ ports for data traffic. I see this is supported config on HWU, however during cluster setup creation it doesnt  create cluster interface lif's and unbale to join the second nodes to switchless cluster
thanks
Ragesh
1 ACCEPTED SOLUTION
3 REPLIES 3
pedro_rocha
Ragesh
yes thanks for that
I have cancelled the cluster creation wizard on both nodes, then modified the network ports to Cluster and 9000 MTU, after re-ran the cluster setup , this helped to resolve the issue
thanks
pedro_rocha
Glad it helped!
