ONTAP Hardware
FAS 3240 / DS2246 configuration issue
CGandvfx
Hi everyone!
I recently bought a used Netapp FAS 3240 and an empty disk shelf DS2246 from eBay. I wanted to set it up from scratch to learn how to configure storage systems. I attached 6 drives of HUC109060css600 (600GB 10K SAS made for IBM). FAS 3240 is connected to DS2246 through QSFP-QSPF cable on 0a. I ran the systems for the first time and went through the option (4) Clean configuration and initialize all disks. Data ONTAP version is 8.0.5 7- mode. I got the error message " PANIC: ../driver/disk/disk.c:22047: Assertion failure. in SK process disk_admin". System is keep booting , then I select maintenance mode boot: below is the results of disk show and sysconfig -v  and aggr status commands
disk show -n
Local System ID: 2017636203
DISK OWNER POOL SERIAL NUMBER HOME
0a.30.4 Not Owned NONE KWHBY3DF
0a.30.3 Not Owned NONE KWHDX6YF
0a.30.5 Not Owned NONE KWHDX5VF
*> sysconfig ?
usage: sysconfig -v [ <slot> ]
*> Sat Feb 27 18:04:58 GMT [monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 is over voltage
Sat Feb 27 18:04:58 GMT [monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 has failed
Sat Feb 27 18:04:58 GMT [monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 DC has failed
Sat Feb 27 18:04:58 GMT [monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan1 Speed is Critical Low (2700 RPM)
Sat Feb 27 18:04:58 GMT [callhome.chassis.ps.degraded:error]: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 2
sysconfig -v
NetApp Release 8.0.5 7-Mode: Sun Jan 20 21:53:54 PST 2013
System ID: 2017636203 ()
System Serial Number: 940001065843 ()
System Rev: H7
System Storage Configuration: Single Path
System ACP Connectivity: NA
slot 0: System Board 2.3 GHz (System Board XVI H7)
Model Name: FAS3240
Part Number: 111-00692
Revision: H7
Serial Number: 9438943791
BIOS version: 5.2.0
Loader version: 3.4
Processors: 4
Processor type: Intel(R) Xeon(R) CPU L5410 @ 2.33GHz
Memory Size: 8192 MB
Memory Attributes: Bank Interleaving
Hoisting
Chipkill ECC
NVMEM Size: 1024 MB of Main Memory Used
CMOS RAM Status: OK
Service Processor Status: Unknown
IPMI: unknown
PKT: unknown
IOXM Status: present
Power: Good
Agent version: N/A
Serial Number: 5010297778
Part Number: 111-00647
Version: B0
slot 0: Dual 10G Ethernet Controller T320E-SFP/KR
Device Type: CT-FE-3
Version Number: T3-SRAM1.1.0-BR1016-02-01-FW7.7.209-DR04
Serial Number: jb04050693
c0a MAC Address: 00:a0:98:54:78:30 (auto-unknown-enabling)
c0b MAC Address: 00:a0:98:54:78:31 (auto-unknown-enabling)
slot 0: Internal BGE 10/100 Ethernet Controller
e0M MAC Address: 00:a0:98:54:78:32 (auto-unknown-down)
e0P MAC Address: 00:a0:98:54:78:33 (auto-100tx-fd-up)
Device Type: BCM5721
Sat Feb 27 18:05:03 GMT [monitor.chassisPower.degraded:notice]: Chassis power is degraded:
Sat Feb 27 18:05:03 GMT [callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED:
slot 0: Dual 10/100/1000 Ethernet Controller G20
e0a MAC Address: 00:a0:98:54:78:2e (auto-unknown-down)
e0b MAC Address: 00:a0:98:54:78:2f (auto-unknown-down)
Device Type: Rev 6
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
Firmware rev: 01.11.06.00
Base WWN: 5:00a098:00353bf:88
Phy State: [0] Enabled, 6.0 Gb/s
[1] Enabled, 6.0 Gb/s
[2] Enabled, 6.0 Gb/s
[3] Enabled, 6.0 Gb/s
QSFP Vendor: Molex Inc.
QSFP Part Number: 112-00177+A0
QSFP Type: Passive Copper 2m ID:01
QSFP Serial Number: 123120027
ID Vendor Model FW Size
30.0 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
30.1 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
30.2 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
30.3 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
30.4 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
30.5 : IBM-ESXS HUC109060CSS60 J2ER 423.1GB (1172123568 512B/sect)
Shelf 30: IOM6 Firmware rev. IOM6 A: 0181 IOM6 B: 0181
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
Base WWN: 5:00a098:00353bf:8c
Phy State: [4] Enabled, 6.0 Gb/s
[5] Enabled, 6.0 Gb/s
[6] Enabled, 6.0 Gb/s
[7] Enabled, 6.0 Gb/s
QSFP Type: Passive Copper 2m ID:00
QSFP Serial Number: 212120056
slot 0: FC Host Adapter 0c (QLogic 2432 rev. 2, L-port, <OFFLINE (hard)>)
Firmware rev: 5.4.100
Host Loop Id: 0
FC Node Name: 5:00a:098003:53bf80
FC Port Name: 5:00a:098003:53bf80
SFP Vendor: AVAGO
SFP Part Number: AFBR-57R6APZ-NA1
SFP Serial Number: B91133HJXS
SFP Capabilities: 1, 2 or 4 Gbit
Link Data Rate: N/A
slot 0: FC Host Adapter 0d (QLogic 2432 rev. 2, L-port, <OFFLINE (hard)>)
Host Loop Id: 0
FC Node Name: 5:00a:098103:53bf80
FC Port Name: 5:00a:098103:53bf80
SFP Vendor: AVAGO
SFP Serial Number: B91133HJXV
Link Data Rate: N/A
slot 0: Intel ICH USB EHCI Adapter u0a (0xdfe01400)
boot0 Micron Technology Real SSD eUSB 2GB, rev 2.00/11.10, addr 2 1936MB 512B/sect (0FF0022700155861)
slot 3: SAS Host Adapter 3a (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
MFG Part Number: USI 6086-000010-03 rev. MP V4.4
Part number: 111-00341+C0
Serial number: ST077BAD093
Date Code: 20111013
Firmware rev: 01.11.00.00
Base WWN: 5:00e004:0001a91:98
Phy State: [0] Disabled
[1] Disabled
[2] Disabled
[3] Disabled
QSFP Vendor: not available
QSFP Part Number: not available
QSFP Type: not available
QSFP Serial Number: not available
slot 3: SAS Host Adapter 3b (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
Date Code: 20111013
Base WWN: 5:00e004:0001a91:9c
Phy State: [4] Disabled
[5] Disabled
[6] Disabled
[7] Disabled
slot 3: SAS Host Adapter 3c (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
Date Code: 20111013
Base WWN: 5:00e004:0001a91:90
[1] Disabled
[2] Disabled
[3] Disabled
slot 3: SAS Host Adapter 3d (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
Date Code: 20111013
Base WWN: 5:00e004:0001a91:94
[5] Disabled
[6] Disabled
[7] Disabled
*> aggr status
Sat Feb 27 18:07:25 GMT [fmmb.instStat.change:info]: no mailbox instance on local side.
Sat Feb 27 18:07:25 GMT [coredump.host.spare.none:info]: No sparecore disk was found for host 0.
Sat Feb 27 18:07:25 GMT [raid.assim.tree.noRootVol:error]: No usable root volume was found!
Disk label processing failed!
unable to run aggr command
No root aggregate or root traditional volume found.
You must specify a root aggregate or traditional volume with
"aggr options <name> root" before rebooting the system.
Do I need Netapp oem drives ? Is there any way I can configure this storage system from scratch? vol and aggr commands
are unable to run !
Thanks in advance!
Hyder
1 ACCEPTED SOLUTION
akiendl
as you already mentioned. you need NetApp drives. Without that you will not be able to boot the system.
ak.
2 REPLIES 2
akiendl
ak.
CGandvfx
Thank you, akiendl !
I will try with Netapp oem drives
