ONTAP Hardware
FAS 8020 and Cluster mode
FERIOLI_M
Hi,
we are changing our fas 3210 in mode 7 with 4 gb fc and 10 gb net connection with a new fas8020.
The question is :
Is it true that with cluster mode works only on fc or only in net ? not with both the two connection?
Thanks
Mirko
1 REPLY 1
aborzenkov
No, it's not true. The only difference is, that if you use SAN in a cluster, supported number of nodes is 8. But those nodes can serve both SAN and NAS.
