ONTAP Hardware
FAS6200 Access
Alex1977
I have a used FAS6220 and I don't know the IP on the management port. How do I access it without ONTAP?
1 ACCEPTED SOLUTION
paul_stejskal
Get a console cable (there probably are USB adapters) and use a standard serial connection. https://kb.netapp.com/onprem/ontap/hardware/What_baud_rate_do_NetApp_controller_serial_console_connections_support
You'll need a 9600 Baud cable.
3 REPLIES 3
Ontapforrum
Could you please elaborate ? What is your objective here. If the IP is not available or no one knows in your IT department, then you will need to physically access the filer and re-configure it.
Alex1977
I bought this storage used. I want to use it in my laboratory. That's why I want to know how to reset it.
paul_stejskal
