ONTAP Hardware
Fas2552 12hd x 900gb : how data raid?
marcocapone
I create a volume on 1 controller.
This raid is 5,4 TB .
Can i have much space with this configuration?
3 REPLIES 3
Sahana
Hi,
Try using the space calculator discussed in this link: http://community.netapp.com/t5/Data-ONTAP-Discussions/NetApp-Usable-Space-Calculator/td-p/76807
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
SeanHatfield
I don't think that calculator factors in ADP.
Sahana
FAS2552/2554 (Active-Active Configuration)
Internal Drive ConfigurationDrive Usable
Capacity (MiB)
Drive Usable
Capacity (GiB)
Root Partition
Size (MiB)
Root Partition
Size (GiB)
Data Partition
Size (GiB)
Data Partitions
Total (GiB)
Data Partitions
Total (TiB)
WAFL Usable
Total (GiB)
WAFL Usable
Total (TiB)
12x 900GB SAS (half populated)857,000836.91147,102144693.264159.564.063743.603.66
FAS2552/2554 (Active-Passive Configuration)
Capacity (MiB)
Drive Usable
Capacity (GiB)
Root Partition
Size (MiB)
Root Partition
Size (GiB)
Data Partition
Size (GiB)
Data Partitions
Total (GiB)
Data Partitions
Total (TiB)
WAFL Usable
Total (GiB)
WAFL Usable
Total (TiB)
12x 900GB SAS (half populated)857,000836.91147,102144693.266239.346.095615.405.48
