ONTAP Hardware
How to restore data from volume in netapp storage system to another netapp storage system
newbeee
any know  experience before?
1 REPLY 1
paulstringfellow
Hi,
so depends a little bit on what you are trying to achive.
the easiest way is to have the volume mirrored to another controller this will contain all active data and snapshots, you can then recover away all you need to.
i'd be starting there though.
