ONTAP Hardware
Head Swap 2500 to 8000 7-mode
StefD
Hi Folks
Looking for any pointers on Moving 2500 HA Pair 7-mode to 8000 7-mode while converting the 2500 into a shelf.
Already have 3 other Shelves attached but numbered 1-3, looking on documents or if any ones done this with these models.
Thanks
Stef
2 REPLIES 2
georgevj
Not Specifically for 2500, but I hope you can use this as a guideline doc.
https://library.netapp.com/ecm/ecm_download_file/ECMP1140601
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
StefD
Thanks Im looking into it now, Will let you know if it helped seems that the best upgrade path is to have disks on the new Head and VOL Copy rather than change the Head.
