ONTAP Hardware
FAS2552 / Shelf 2246 Attention LED on
ggonzalez
Hi ...
I have an installation of FAS2552 with a Shelf 2246.
We configured this system in a small FlexPod, using Cisco Nexus 3048 and Cisco UCS Servers C240M3.
The system is working OK, but I the Attention LED in Shelf is ON.
I was checking the documentation related to this alert, after that I checked the infrastructure:  Nexus configuration (vPC), interfaces, etc ...   but I don't see the cause.
Is there any way to turn off the attentio led ?
How could I verify the problem related ?
I'll appreciate any suggestion.
5 REPLIES 5
YIshikawa
How "show_faults" and "fru_led status" shows? Both commads are availabe in diag mode in 7-mode or nodeshell of Clustered Data ONTAP? Also check if any abnormal status are reported in " environment status".
If you have an access to SP, "events all" in SP CLI may give you some clue.
These collection should be done on both controller A and B.
ggonzalez
Thanks ...
I used the SP console and "system node run -node XXXX" to see the events and alarms.
I don't see any error but I still have the LEDs on (FAS2552 and 2246).
Any suggestion ?
YIshikawa
It is hard  for me to track fault events in "events all", too many suspicious events here.
Can you collect "show_faults" and "fru_led status" on cluster shell like below?
cluster::> set diag
cluster::*> system node run -node * show_faults
cluster::*> system node run -node * fru_led status
cluster::*> set admin
Fault LED sometimes stay on even after fault state get cleared.
 If no error is reported in "show_faults" and no FRU LED is on, clear LED and check if LED become on again.
cluster::> set diag
cluster::*> system node run -node node fru_led off all
ggonzalez
Thanks for your help.
We are checking the disk.
I could see all LEDs off following the commands before.
The only issue is a new warning related to Aggregate used in 88%.
Is there any way to configure the threshold of this warning to other value ( 90% ) and how we can off this warning ?
Thanks in advance.
YIshikawa
Unfortunately, this threshould is not configurable.
