ONTAP Hardware
Problem configuration BMC on NetApp filer
Takeover
Hello everybody,
I encouter a second problem, when I try to configure BMC, all is alright except the configuration of the speed and the duplex, I don't understand why it doesn't to work.
When I try to execute the command to configure the speed and the duplex I obtain this error message : "Command execution failed"
Thank you for your help.
2 REPLIES 2
hariprak
Hi,
Hope this KB article helps https://kb.netapp.com/support/index?page=content&id=3011254&actp=search&viewlocale=en_US&searchid=1427293949480
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Takeover
Hello,
I have seen the article but the configuration don't work, I enter theses commande :
bmc config speed 100
and
bmc config duplex full
And I encountered this result : "Command execution failed !"
