ONTAP Hardware
How do you work out Disk shelves on say a FAS8040
Stu_Gregory
Hi All,
I am new to the hardware so please go easy on me,
I am looking for a guide on you can work out how many more Disk Shelves you can put into a Cluster.
In my cluster of 2x FAS8040's a "storage shelf show" command shows me 8x DS2246 all with IOM6 Modules.
Do I take this as 4 Shelves within each node?
How do I work out how many more shelves can I put in?
Regards, Stu
1 ACCEPTED SOLUTION
Naveenpusuluru
Hi @Stu_Gregory
Please login to below portal.
hwu.netapp.com
Then you can able to see all the hardware and software compatabilities.... 🙂
Naveen Kumar Pusuluru
Storage lead, C3i Healthcare connections
Kudos and accepted solutions are always appreciated.
8 REPLIES 8
Naveenpusuluru
You can put maximum of 30 disk shelfs of DS2246 for 8040 HA- cluster. Please find the below screenshot for your reference.
Naveenpusuluru
Is this what you need? ...
Stu_Gregory
where did you get the above info from, is there a portal?
Naveenpusuluru
Hi @Stu_Gregory
hwu.netapp.com
Brandon_M_Boyd
Where does that resolve?  hwu.netapp.com does not resolve for me.
Naveenpusuluru
Please find the below screenshot.
hwu.netapp.com
Stu_Gregory
Hi
Try using Internet Explorer or Firefox, Chrome seems to not work as it should for me (if thats what you are using?)
Stu
Naveenpusuluru
If you already login to netapp support from the current browser, please logout from support site and type hwu.netapp.com. It will ask you for login credentials , Please use your support site credentials. You must have partner or customer access to support site to use this site. It won't work with guest user access.
