ONTAP Hardware
How to identify empty expansion slots in netapp
RAJATGARG
Is there a command to identify empty expansion slots in netapp ?
2 REPLIES 2
nitish
Try the following:
1.  fcadmin device_map
2. sasadmin shelf <adapter>
The missing numbers (representing disks) should tell you what slots are empty.
cscott
Assuming a 7 mode system:
sysconfig -ca will show you what part is in each slot, and by elimination you can tell what slots are free, in my lab slot 3 and 4 are open.  This command is great for knowing what the NetApp part number for your cards is as well!
Assuming a Clustered OnTap system
system node run -node <NODENAME> -command sysconfig -ca
sysconfig -ca
sysconfig: slot 5 OK: X1936A: Performance Acceleration Module I
sysconfig: slot 6 OK: X1107A: Chelsio S320E 2x10G NIC
sysconfig: slot 1 OK: X3148: NetApp NVRAM6 2GB
sysconfig: slot 2 OK: X2054A: QLogic ISP 2432; PCI-E quad-port Fibre Channel (QLE2464)
sysconfig: slot 7 OK: X2054A: QLogic ISP 2432; PCI-E quad-port Fibre Channel (QLE2464)
sysconfig: slot 8 OK: X2054A: QLogic ISP 2432; PCI-E quad-port Fibre Channel (QLE2464)
- Scott
