ONTAP Hardware
Fiber Channel Port [LINK NOT CONNECTED]
unitech89e9
I have a dua-chassis HA system,
The model is fas3220,
Node-A perform FC,
and Node-B perform CIFS,
When I config all the system,
I test the HA function,
When I use the command [cf takeover] in node-B,
it takeover success,
but my windows can't see the lun in windows disk manager!
I go to see the hardware,
and found that the fc port(0c and 0d) led is not light!
when I use the command [sysconfig -a],
I see the 0c and 0d is <LINK NOT CONNECTED>!
and I found the Host Port Addr is 000000
if use the [fcp config],
and it show [LINK NOT CONNECTED <ADAPTER UP>]
I see the port on the san switch,
NASB> sysconfig -a
        Data ONTAP Release 8.1.3P3 7-Mode: Sun Sep 22 22:29:18 PDT 2013
        System ID: 2018635319 (NASB); partner ID: 2018635377 (NASA)
        System Serial Number:  (NASB)
        System Rev: B0
        System Storage Configuration: Single-Path HA
        System ACP Connectivity: Partial Connectivity
        slot 0: System Board 2.3 GHz (System Board XVI B0)
                Model Name:         NAS
                Machine Type:
                Part Number:        111-01333
                Revision:           B0
                Serial Number:      9448934956
                BIOS version:       5.2.1
                Loader version:     3.4
                Processors:         4
                Processor ID:       0x1067a
                Microcode Version:  0xa0b
                Processor type:     Intel(R) Xeon(R) CPU           L5410  @ 2.33GHz
                Memory Size:        12288 MB
                Memory Attributes:  Bank Interleaving
                                    Hoisting
                                    Rank Interleaving
                                    Chipkill ECC
                NVMEM Size:         1600 MB of Main Memory Used
                CMOS RAM Status:    OK
        Service Processor           Status: Online
                Firmware Version:   1.3.3
                Mgmt MAC Address:   00:A0:98:5A:FF:82
                Ethernet Link:      up, 100Mb, full duplex, auto-neg complete
                Using DHCP:         yes
        IPv4 configuration:
                IP Address:         unknown
                Netmask:            unknown
                Gateway:            unknown
        IPv6 configuration:         Disabled
        slot 0: Dual 10G Ethernet Controller T320E-SFP/KR
                Device Type:        CT-FE-3
                Version Number:     T3-SRAM1.1.0-BR1016-02-01-FW7.7.209-DR04
                Serial Number:      jb04050693
                c0a MAC Address:    00:a0:98:5a:ff:7e (auto-10g_twinax-fd-up)
                c0b MAC Address:    00:a0:98:5a:ff:7f (auto-10g_twinax-fd-up)
                        memory mapped I/O base 0xde801000, size 0x1000
                        memory mapped I/O base 0xde000000, size 0x800000
                        memory mapped I/O base 0xde800000, size 0x1000
        slot 0: Internal BGE 10/100 Ethernet Controller
                e0M MAC Address:    00:a0:98:5a:ff:80 (auto-100tx-fd-up)
                e0P MAC Address:    00:a0:98:5a:ff:81 (auto-100tx-fd-up)
                Device Type:        BCM5721
                        memory mapped I/O base 0xdf800000, size 0x10000
                        memory mapped I/O base 0xdf900000, size 0x10000
        slot 0: Dual 10/100/1000 Ethernet Controller G20
                e0a MAC Address:    00:a0:98:5a:ff:7c (auto-1000t-fd-up)
                e0b MAC Address:    00:a0:98:5a:ff:7d (auto-1000t-fd-up)
                Device Type:        Rev 6
                        memory mapped I/O base 0x00000000df720000, size 0x20000
                        memory mapped I/O base 0x00000000df700000, size 0x20000
                        I/O base 0x0000000000003000, size 0x20
                        memory mapped I/O base 0x00000000df760000, size 0x20000
                        memory mapped I/O base 0x00000000df740000, size 0x20000
                        I/O base 0x0000000000003020, size 0x20
        slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
                Firmware rev:       01.11.07.00
                Base WWN:           5:00a098:00364ea:d8
                Phy State:          [0] Enabled, 6.0 Gb/s
                                    [1] Enabled, 6.0 Gb/s
                                    [2] Enabled, 6.0 Gb/s
                                    [3] Enabled, 6.0 Gb/s
                QSFP Vendor:        Molex Inc.
                QSFP Part Number:   112-00177+A0
                QSFP Type:          Passive Copper 2m ID:01
                QSFP Serial Number: 408720174
                02.0 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4DDSP)
                02.1 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4GWPP)
                02.2 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4PE1P)
                02.3 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4LDNP)
                02.4 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4K6KP)
                02.5 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4689P)
                02.6 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4GWRP)
                02.7 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J467YP)
                02.8 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J466VP)
                02.9 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J5053P)
                02.10: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J4WVNP)
                02.11: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J5044P)
                02.12: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB 512B/sect (P6J504GP)
                03.0 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1277461)
                03.1 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272876)
                03.2 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274858)
                03.3 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274741)
                03.4 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274793)
                03.5 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1273338)
                03.6 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1271576)
                03.7 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272160)
                03.8 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1273637)
                03.9 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1274446)
                03.10: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1272310)
                03.11: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1277264)
                03.12: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB 512B/sect (WD-WCC1P1275875)
                Shelf   2: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
                Shelf   3: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
        slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <UP>)
                Base WWN:           5:00a098:00364ea:dc
                Phy State:          [4] Enabled, 6.0 Gb/s
                                    [5] Enabled, 6.0 Gb/s
                                    [6] Enabled, 6.0 Gb/s
                                    [7] Enabled, 6.0 Gb/s
                QSFP Type:          Passive Copper 2m ID:00
                QSFP Serial Number: 408720161
                00.0 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMJHWF)
                00.1 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ2NF)
                00.2 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGG3YAM)
                00.3 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ67F)
                00.4 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGJ7V4R)
                00.5 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNYTGF)
                00.6 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGNZ2JF)
                00.7 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMRH8M)
                00.8 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMU9NM)
                00.9 : NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMW1PM)
                00.10: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMT8XM)
                00.11: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMSGYM)
                00.12: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGKNH0M)
                00.13: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGK33SR)
                00.14: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMRPDM)
                00.15: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGL17AM)
                00.16: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGEX0XR)
                00.17: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMSYMM)
                00.18: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGEJHVM)
                00.19: NETAPP   X422_HCOBE600A10 NA00 560.0GB 520B/sect (KWGMJ4UF)
                01.0 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0OCFUZ6)
                01.1 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0NJFUZ6)
                01.2 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0MRFUZ6)
                01.3 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A058FUZ6)
                01.4 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0MBFUZ6)
                01.5 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A055FUZ6)
                01.6 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0LMFUZ6)
                01.7 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0L4FUZ6)
                01.8 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0KOFUZ6)
                01.9 : NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44O0A0N7FUZ6)
                01.10: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A05BFUZ6)
                01.11: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A06YFUZ6)
                01.12: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A05RFUZ6)
                01.13: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0ELFUZ6)
                01.14: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A0AXFUZ6)
                01.15: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A05JFUZ6)
                01.16: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0EBFUZ6)
                01.17: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A04ZFUZ6)
                01.18: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44N0A09JFUZ6)
                01.19: NETAPP   X422_TAL13600A10 NA01 560.0GB 520B/sect (44M0A0E3FUZ6)
                Shelf   0: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
                Shelf   1: IOM6  Firmware rev. IOM6 A: 0162 IOM6 B: 0162
                        memory mapped I/O base 0xdf530000, size 0x10000
                        memory mapped I/O base 0xdf520000, size 0x10000
                        memory mapped I/O base 0x00000000df510000, size 0x10000
                        memory mapped I/O base 0x00000000df500000, size 0x10000
        slot 0: Fibre Channel Target Host Adapter 0c
                (QLogic 2432 (2462) rev. 2, <LINK NOT CONNECTED>)
                Firmware rev:      5.5.2
                Host Port Addr:    000000
                FC Nodename:       50:0a:09:80:88:31:ee:71 (500a09808831ee71)
                FC Portname:       50:0a:09:81:98:31:ee:71 (500a09819831ee71)
                Connection:        No link
                Switch Port:       Unknown
                SFP Vendor Name:   FINISAR CORP.
                SFP Vendor P/N:    FTLF8524P2BNV
                SFP Vendor Rev:    A
                SFP Serial No.:    PQS1F0P
                SFP Connector:     LC
                SFP Capabilities:  1, 2, 4 Gbit/Sec
                        I/O base 0x0000000000002000, size 0x100
                        memory mapped I/O base 0xdf600000, size 0x4000
        slot 0: Fibre Channel Target Host Adapter 0d
                Firmware rev:      5.5.2
                FC Portname:       50:0a:09:82:98:31:ee:71 (500a09829831ee71)
                Connection:        No link
                SFP Vendor Rev:    A
                SFP Serial No.:    PQR1XQU
                SFP Connector:     LC
                        I/O base 0x0000000000002400, size 0x100
                        memory mapped I/O base 0xdf604000, size 0x4000
        slot 0: Intel ICH USB EHCI Adapter u0a (0xdfa01400)
                boot0   Micron Technology Real SSD eUSB 2GB, class 0/0, rev 2.00/11.10, addr 2 1936MB 512B/sect (B8F0022700288919)
                        memory-mapped I/O base 0xdfa01400, size 0x400
        slot 1: FC Host Adapter 1a (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
                Board name:        QLE2564
                Serial Number:     RFD1404U24554
                Firmware rev:      5.4.130
                Host Loop Id:      0
                FC Node Name:      2:000:0024ff:730e94
                FC Port Name:      2:100:0024ff:730e94
                SFP Vendor:        AVAGO
                SFP Part Number:   AFBR-57D9AMZ-QL
                SFP Serial Number: AA13323A6CX
                SFP Capabilities:  2, 4 or 8 Gbit
                Link Data Rate:    N/A
                        I/O base 0x00000000ffffff00, size 0x100
                        memory mapped I/O base 0xdee00000, size 0x4000
                        memory mapped I/O base 0xdec00000, size 0x100000
        slot 1: FC Host Adapter 1b (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
                Board name:        QLE2564
                Host Loop Id:      0
                FC Node Name:      2:000:0024ff:730e95
                FC Port Name:      2:100:0024ff:730e95
                SFP Vendor:        AVAGO
                SFP Serial Number: AA13323A69L
                Link Data Rate:    N/A
                        memory mapped I/O base 0xdee04000, size 0x4000
                        memory mapped I/O base 0xded00000, size 0x100000
        slot 1: FC Host Adapter 1c (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
                Board name:        QLE2564
                Host Loop Id:      0
                FC Node Name:      2:000:0024ff:730e96
                FC Port Name:      2:100:0024ff:730e96
                SFP Vendor:        AVAGO
                SFP Serial Number: AA13323A6CV
                Link Data Rate:    N/A
                        memory mapped I/O base 0xdf100000, size 0x4000
                        memory mapped I/O base 0xdef00000, size 0x100000
        slot 1: FC Host Adapter 1d (QLogic 2532 rev. 2, L-port, <OFFLINE (hard)>)
                Board name:        QLE2564
                Host Loop Id:      0
                FC Node Name:      2:000:0024ff:730e97
                FC Port Name:      2:100:0024ff:730e97
                SFP Vendor:        AVAGO
                SFP Serial Number: AA13323A6D1
                Link Data Rate:    N/A
                        memory mapped I/O base 0xdf104000, size 0x4000
                        memory mapped I/O base 0xdf000000, size 0x100000
        slot 2: FCVI Host Adapter 2a (QLogic 2532(2562) rev. 2, unknown, <DOWN>)
                Physical link: DOWN
                FC Node Name:   21:00:00:24:ff:58:4f:58
                Firmware rev:   5.3.140 Serial No:      BFD1408T29623
                Host Port Id:   0xffffffff
                Cacheline size: 8       FC Packet size: 2048
                SFP Vendor:     FINISAR CORP.
                SFP Part Number:        FTLF8528P3BCV-QL
                SFP Serial Number:      PR11JG5
                        memory mapped I/O base 0xdf200000, size 0x4000
        slot 2: FCVI Host Adapter 2b (QLogic 2532(2562) rev. 2, unknown, <DOWN>)
                Physical link: DOWN
                FC Node Name:   21:00:00:24:ff:58:4f:59
                SFP Serial Number:      PR224BN
                        memory mapped I/O base 0xdf204000, size 0x4000
NASB>
NASB>
NASB>
NASB>
NASB>
NASB>
NASB> sysconfig -a       v
        System Serial Number: 2858C2513F009111 (NASB)
        System Rev: B0
                Model Name:         NAS
                Machine Type:
                Revision:           B0
                BIOS version:       5.2.1
                Loader version:     3.4
                Processors:         4
                                    Hoisting
                                    Rank Interleaving
                                    Chipkill ECC
                CMOS RAM Status:    OK
                Using DHCP:         yes
        IPv4 configuration:
                IP Address:         unknown
                Netmask:            unknown
                Gateway:            unknown
                Device Type:        Rev 6
                 ID     Vendor   Model            FW    Size
                02.0 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.1 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.2 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.3 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.4 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.5 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.6 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.7 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.8 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.9 : NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.10: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.11: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                02.12: NETAPP   X306_HMRKP02TSSA NA00 1695.4GB (3907029168 512B/sect)
                03.0 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.1 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.2 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.3 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.4 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.5 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.6 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.7 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.8 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.9 : NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.10: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.11: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                03.12: NETAPP   X306_WKOJN02TSSA NA01 1695.4GB (3907029168 512B/sect)
                00.0 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.1 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.2 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.3 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.4 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.5 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.6 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.7 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.8 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.9 : NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.10: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.11: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.12: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.13: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.14: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.15: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.16: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.17: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.18: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                00.19: NETAPP   X422_HCOBE600A10 NA00 560.0GB (1172123568 520B/sect)
                01.0 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.1 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.2 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.3 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.4 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.5 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.6 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.7 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.8 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.9 : NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.10: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.11: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.12: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.13: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.14: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.15: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.16: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.17: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.18: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                01.19: NETAPP   X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
                Firmware rev:      5.5.2
                Connection:        No link
                SFP Vendor Rev:    A
                SFP Connector:     LC
                Firmware rev:      5.5.2
                Connection:        No link
                SFP Vendor Rev:    A
                SFP Connector:     LC
                Board name:        QLE2564
                Host Loop Id:      0
                SFP Vendor:        AVAGO
                Link Data Rate:    N/A
                Board name:        QLE2564
                Host Loop Id:      0
                SFP Vendor:        AVAGO
                Link Data Rate:    N/A
                Board name:        QLE2564
                Host Loop Id:      0
                SFP Vendor:        AVAGO
                Link Data Rate:    N/A
                Board name:        QLE2564
                Host Loop Id:      0
                SFP Vendor:        AVAGO
                Link Data Rate:    N/A
                Physical link: DOWN
                Physical link: DOWN
NASB>
NASB>
NASB>
NASB>
NASB>
NASB>
NASB> fcp config
0c:   LINK NOT CONNECTED <ADAPTER UP>
        host address 000000
        portname 50:0a:09:81:98:31:ee:71  nodename 50:0a:09:80:88:31:ee:71
        mediatype auto speed auto
0d:   LINK NOT CONNECTED <ADAPTER UP>
        host address 000000
        portname 50:0a:09:82:98:31:ee:71  nodename 50:0a:09:80:88:31:ee:71
NASB>
NASB>
NASB>
NASB>
NASB> fcp topology show
Switches connected on adapter 0c:
        None connected.
Switches connected on adapter 0d:
        None connected.
NASB>
NASB>
NASB>
NASB>
NASB> fcp portname show
Portname                  Adapter
50:0a:09:81:98:31:ee:71   0c
50:0a:09:82:98:31:ee:71   0d
NASB>
NASB>
NASB>
NASB>
NASB> fcp nodename
Fibre Channel nodename: 50:0a:09:80:88:31:ee:71 (500a09808831ee71)
NASB>
NASB>
NASB>
NASB>
NASB>
NASB> fcp status
FCP service is running.
NASB>
NASB>
NASB>
NASB>
NASB>
NASB>
NASB> fcp wwpn-alias show
NASB>
NASB>
NASB>
NASB>
NASB>
NASB> fcadmin config
                  Local
Adapter Type      State                  Status
  0c   target     CONFIGURED             online
  0d   target     CONFIGURED             online
  1a   initiator  CONFIGURED.            offline
  1b   initiator  CONFIGURED.            offline
  1c   initiator  CONFIGURED.            offline
  1d   initiator  CONFIGURED.            offline
NASB>
5 REPLIES 5
radek_kubka
Are relevant ports on FC switch enabled? Did you try removing / reinserting / using different FC cables?
Regards,
Radek
unitech89e9
Hi radek :
The switch port is enable,
but when I plug the cable,
it will become U port,
and the enable and disable button can't be click(diable)!
I have chang many FC Cable,
I event switch the other Controller,
change the owner ship the other controller,
and plug all the cable!
but the same!
radek_kubka
Is it 8Gbit switch by any chance? Google search suggests port going into U-state may be related to speed auto-negotiation issues.
Try setting the port speed on the switch to 4Gbit.
Other than that, you may try swapping SFPs around & see what happens.
unitech89e9
Hi Radek:
This way I have try,
but can't finish!
And the partner controller is also 4Gb,
but it working normally!
DOMINIC_WYSS
have you accidentally forgotten to start (or license) fcp on the second node?
fcp start
fcp status
license
