ONTAP Hardware
How to list all lun serial numbers on netapp
netapptema
Hi guys;
I'm the new about netapp.
I hope I'll find a solution about LUN in here.
I wanna list all lun but the list must contain only details of lun path and lun serial number.
"lun show -v" display all details of luns.
Any idea ?
Thanks.
1 ACCEPTED SOLUTION
Darkstar
A quick way is to do the following:
fas3020c1> stats list instances lun
Instances for object name: lun
        /vol/esxX_Boot/LUNs/slesx5.lun-C4iRVoX0ZVhf
        /vol/esxX_Boot/LUNs/slesx4.lun-C4iRVoWqMs1a
        /vol/esxX_Boot/LUNs/slesx3.lun-C4iRVoWqMrwj
        /vol/esxX_Boot/LUNs/slesx1.lun-C4iRVoWqMmq7
        /vol/esxX_Boot/LUNs/slesx2.lun-C4iRVoWqMrq8
it gives you the unique LUN "id" that is used for stats monitoring, which just happens to be the LUN path followed by the LUN serial, separated by a hyphen.
-Michael
2 REPLIES 2
eric_barlier
Hi and welcome
Have you got operations manager installed? even if you do AFAIK your only options are doing it via OM and then excel. Or via scripting. There is no CLI on the controller
that will give you exactly those two pieces of info.
Eric
Darkstar
-Michael
