ONTAP Hardware
Model Name:FAS3240:Ethernet e0M: Link down, check cable(give back not happening)
PvN
add host 127.0.10.1: gateway 127.0.20.1
WAFL CPLEDGER is enabled. Checklist = 0x7ff841ff
Feb 18 11:18:56 [localhost:wafl.memory.status:info]: 2293MB of memory is currently available for the WAFL file system.
Feb 18 11:18:56 [localhost:dcs.framework.enabled:info]: The DCS framework is enabled on this node.
Feb 18 11:18:56 [localhost:fmmb.current.lock.disk:info]: Disk 4a.20.0 is a local HA mailbox disk.
Feb 18 11:18:56 [localhost:fmmb.current.lock.disk:info]: Disk 4a.20.1 is a local HA mailbox disk.
Feb 18 11:18:56 [localhost:fmmb.instStat.change:info]: normal mailbox instance on local side.
Feb 18 11:18:58 [localhost:fmmb.current.lock.disk:info]: Disk 4b.12.11 is a partner HA mailbox disk.
Feb 18 11:18:58 [localhost:fmmb.current.lock.disk:info]: Disk 4a.21.19 is a partner HA mailbox disk.
Feb 18 11:18:58 [localhost:fmmb.instStat.change:info]: normal mailbox instance on partner side.
Feb 18 11:18:58 [localhost:cf.fm.partner:info]: Failover monitor: partner 'gructinasf8002a'
Feb 18 11:19:04 [localhost:snmp.link.up:info]: Interface 11 is up
Feb 18 11:19:04 [localhost:netif.linkUp:info]: Ethernet c0a: Link up.
please suggest
Feb 18 11:19:04 [localhost:snmp.link.up:info]: Interface 12 is up
Feb 18 11:19:04 [localhost:netif.linkUp:info]: Ethernet c0b: Link up.
Feb 18 11:19:05 [localhost:snmp.link.up:info]: Interface 14 is up
Feb 18 11:19:05 [localhost:netif.linkUp:info]: Ethernet e0P: Link up.
Feb 18 11:19:06 [iwarp-vfiler@localhost:ctrl.rdma.heartBeat:info]: HA interconnect: Starting heartbeat to 192.168.1.161.
Feb 18 11:19:06 [iwarp-vfiler@localhost:ctrl.rdma.heartBeat:info]: HA interconnect: Starting heartbeat to 192.168.2.65.
Feb 18 11:19:07 [localhost:snmp.link.up:info]: Interface 4 is up
Feb 18 11:19:07 [localhost:netif.linkUp:info]: Ethernet e5b: Link up.
Feb 18 11:19:07 [localhost:snmp.link.down:info]: Interface 1 is down.
Feb 18 11:19:07 [localhost:netif.linkDown:info]: Ethernet e0a: Link down, check cable.
Feb 18 11:19:07 [localhost:snmp.link.down:info]: Interface 2 is down.
Feb 18 11:19:07 [localhost:netif.linkDown:info]: Ethernet e0b: Link down, check cable.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 5 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e5c: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 6 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e5d: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 3 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e5a: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 9 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e6c: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 7 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e6a: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 10 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e6d: Link up.
Feb 18 11:19:08 [localhost:snmp.link.up:info]: Interface 8 is up
Feb 18 11:19:08 [localhost:netif.linkUp:info]: Ethernet e6b: Link up.
Feb 18 11:19:09 [localhost:snmp.link.down:info]: Interface 13 is down.
Feb 18 11:19:09 [localhost:netif.linkDown:info]: Ethernet e0M: Link down, check cable.
Waiting for giveback...(Press Ctrl-C to abort wait)
This node was previously declared dead.
Pausing to check HA partner status ...
partner is operational and in takeover mode.
You must initiate a giveback or shutdown on the HA
partner in order to bring this node online.
slot 0: System Board 2.3 GHz (System Board XVI A2)
Model Name: FAS3240
Part Number: 111-01010
Revision: A2
Serial Number: 9408320713
BIOS version: 5.3.0
Loader version: 3.6
Processors: 4
Processor ID: 0x1067a
Microcode Version: 0xa0b
Processor type: Intel(R) Xeon(R) CPU L5410 @ 2.33GHz
Memory Size: 8192 MB
Memory Attributes: Bank Interleaving
Hoisting
Chipkill ECC
NVMEM Size: 1024 MB of Main Memory Used
CMOS RAM Status: OK
Controller: A
Service Processor Status: Online
Firmware Version: 1.4.4P2
Mgmt MAC Address: 00:A0:98:38:29:94
Ethernet Link: down
Using DHCP: no
IPv4 configuration:
IP Address: 163.35.239.200
Netmask: 255.255.255.128
Gateway: 163.35.239.129
IPv6 configuration: Disabled
[Service Processor cached network information determined at Sat Feb 18 14:33:26 -03 2023]
IOXM Status: present
Power: Good
CPLD version:
Agent version: N/A
Serial Number: 9408692946
Part Number: 111-00647
Version: C0
slot 0: Dual 10G Ethernet Controller T320E-SFP/KR
Device Type: CT-FE-3
Version Number: T3-SRAM1.1.0-BR1016-02-01-FW7.7.209-DR04
Serial Number: jb04050693
c0a MAC Address: 00:a0:98:38:29:90 (auto-10g_twinax-fd-up)
c0b MAC Address: 00:a0:98:38:29:91 (auto-10g_twinax-fd-up)
memory mapped I/O base 0xde001000, size 0x1000
memory mapped I/O base 0xdd800000, size 0x800000
memory mapped I/O base 0xde000000, size 0x1000
slot 0: Internal BGE 10/100 Ethernet Controller
e0M MAC Address: 00:a0:98:38:29:92 (auto-unknown-down)
e0P MAC Address: 00:a0:98:38:29:93 (auto-100tx-fd-up)
Device Type: BCM5721
memory mapped I/O base 0xdf600000, size 0x10000
memory mapped I/O base 0xdf700000, size 0x10000
slot 0: Dual 10/100/1000 Ethernet Controller G20
e0a MAC Address: 00:a0:98:38:29:8e (auto-unknown-down)
e0b MAC Address: 00:a0:98:38:29:8f (auto-unknown-down)
Device Type: Rev 6
memory mapped I/O base 0x00000000df520000, size 0x20000
memory mapped I/O base 0x00000000df500000, size 0x20000
I/O base 0x0000000000003000, size 0x20
memory mapped I/O base 0x00000000df560000, size 0x20000
memory mapped I/O base 0x00000000df540000, size 0x20000
I/O base 0x0000000000003020, size 0x20
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
Firmware rev: 01.12.09.00
Base WWN: 5:00a098:0012b1d:48
Phy State: [0] Disabled
[1] Disabled
[2] Disabled
[3] Disabled
QSFP Vendor: not available
QSFP Part Number: not available
QSFP Type: not available
QSFP Serial Number: not available
slot 0: SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C, SAS, <OFFLINE (hard)>)
Base WWN: 5:00a098:0012b1d:4c
Phy State: [4] Disabled
[5] Disabled
[6] Disabled
[7] Disabled
memory mapped I/O base 0xdf430000, size 0x10000
memory mapped I/O base 0xdf420000, size 0x10000
memory mapped I/O base 0x00000000df410000, size 0x10000
memory mapped I/O base 0x00000000df400000, size 0x10000
slot 0: FC Host Adapter 0c (QLogic 2432 rev. 2, L-port, <OFFLINE (hard)>)
Firmware rev: 5.4.100
Host Loop Id: 0
FC Node Name: 5:00a:098001:2b1d40
FC Port Name: 5:00a:098001:2b1d40
SFP Vendor: AVAGO
SFP Part Number: AFBR-57R6APZ-NA1
SFP Serial Number: B812350YHU
SFP Capabilities: 1, 2 or 4 Gbit
Link Data Rate: N/A
I/O base 0x0000000000002000, size 0x100
memory mapped I/O base 0xdf300000, size 0x4000
slot 0: FC Host Adapter 0d (QLogic 2432 rev. 2, L-port, <OFFLINE (hard)>)
Host Loop Id: 0
FC Node Name: 5:00a:098101:2b1d40
FC Port Name: 5:00a:098101:2b1d40
SFP Vendor: AVAGO
SFP Serial Number: B812350YHP
Link Data Rate: N/A
I/O base 0x0000000000002400, size 0x100
memory mapped I/O base 0xdf304000, size 0x4000
slot 0: Intel USB EHCI Adapter u0a (0xdf801400)
boot0 Micron Technology 0x655, class 0/0, rev 2.00/11.10, addr 2 1936MB 512B/sect (B8F0022700081879)
memory-mapped I/O base 0xdf801400, size 0x00000400
slot 1: Flash Cache (512 GB)
State: Enabled
Model Name: X1971A-R5
Serial Number: 9409721392
Part Number: 111-00708
Board Revision: E1
FPGA Release: 2.3
FPGA Build: 201204251259
memory mapped I/O base 0xde410000, size 0x1000
memory mapped I/O base 0xde400000, size 0x10000
slot 3: SAS Host Adapter 3a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
MFG Part Number: USI 6086-000010-06 rev. MP V4.9
Part number: 111-00341+F1
Serial number: ST062CCE043
Date Code: 20121214
Base WWN: 5:00e004:00024d9:c8
Phy State: [0] Enabled, 3.0 Gb/s
[1] Enabled, 3.0 Gb/s
[2] Enabled, 3.0 Gb/s
[3] Enabled, 3.0 Gb/s
QSFP Vendor: Molex Inc.
QSFP Part Number: 112-00177+A0
QSFP Type: Passive Copper 2m ID:00
QSFP Serial Number: 229320380
1 ACCEPTED SOLUTION
michelef
From the picture you posted the e0M interface is not cabled:
This should not prevent a giveback though.
  • Boot this node until you see this prompt: "Waiting for giveback...(Press Ctrl-C to abort wait)"
  • Leave it there and connect to the HA partner.
  • On the HA partner the command 'cf status' will tell you if it's ready for giveback.
  • Run the command 'cf giveback' to perform the giveback.
  • If it fails it should report a reason why.
5 REPLIES 5
AlexDawson
Looks ok as far as I can tell. Make sure all the SAS cables are plugged in tightly, then plug the serial cable into the other controller, login and type "cf giveback"
PvN
let me check that, will get back to you with updates.
PvN
what about eM0 port its showing down ?
michelef
PvN
Thanks Michelef, will update you on the status by today.
