ONTAP Hardware
Multi-Pathing issues with EVA 4400 and V3240
JAVA_CAT33
I've currently got 2 V3240 controllers zoned (single initiator, single target) to an HP EVA 4400.
There are 2 fabrics and I've got 2 initiators configured per controller (3a and 3c). Below is the zoning setup.
SwitchV-Series System PortEVA ControllerEVA Array Port
1Node1 - 3aController 2FP1
1Node2 - 3aController 1FP1
2Node1 - 3cController 1FP2
2Node2 - 3cController 2FP2
The issue I've got at present is that the controllers are only seeing 1 path to the disk. The controllers can see both fabrics.
There error I receive on the controller console is the following:
Fibre Channel device <switchname>:1.126 with WWNN 50014380025aca70 was discovered on array optimized adapter port 3c. The same WWNN was already discovered on non-optimized port 3a. The path through 3c will not be used.
I've checked the EVA controllers - they both have the same WWNN which I believe could be the issue. Is this normal for an EVA? Keen to hear from anyone who has seen this problem or knows how to resolve.
Thanks
1 ACCEPTED SOLUTION
thomas_glodde
Refer to KB 2012228 "V-Series: WWNN discovered on non-array optimized adapter".
You might need to check and edit a few system variables to fix this issue.
2 REPLIES 2
thomas_glodde
JAVA_CAT33
Thanks for your help - resolved the issue after following the kb.
