ONTAP Hardware
New setup A250 Fiber channel - Cisco MDS port showing not connected
dirkdigs
Hello i have cabled everything up. Switch is Cisco MDS 9148. Netapp is A250 with each node having quad port FC adapter.
Using 16Gb OEM Cisco transceiver on Cisco side.
I have tried so many different things, but the ports are still showing not connected on the switch side.
Does anyone have any tricks up their sleeve that they might want to share with me? This is simple layer 1 connectivity issue but i feel like i am missing something. thanks, ,
patch cable is 5-meter OM4  OFNP
4 REPLIES 4
AlexDawson
9148 or 9148S? 9148 is an 8Gb only switch. 9148S supports 16Gb.
show interface fcX/X transceiver details from the cisco side should show if there's light coming through.
dirkdigs
MDS 9148S 16G 48 FC
san-sw01# sh int fc1/19 transceiver details
fc1/19 sfp is present
Name is CISCO-FINISAR
Manufacturer's part number is FTLF8529P4BCV-C1
Revision is A
Serial number is FNS26280S6H
Cisco part number is 10-2666-01
Cisco pid is DS-SFP-FC16G-SW
FC Transmitter type is short wave laser w/o OFC (SN)
FC Transmitter supports short distance link length
Transmission medium is multimode laser with 62.5 um aperture (M6)
Supported speeds are - Min speed: 4000 Mb/s, Max speed: 16000 Mb/s
Nominal bit rate is 14000 Mb/s
Link length supported for 50/125um OM2 fiber is 35 m
Link length supported for 62.5/125um fiber is 15 m
Link length supported for 50/125um OM3 fiber is 100 m
Cisco extended id is unknown (0x0)
No tx fault, rx loss, no sync exists, diagnostic monitoring type is 0x68
SFP Diagnostics Information:
Alarms Warnings
High Low High Low
Temperature 30.27 C 75.00 C -5.00 C 70.00 C 0.00 C
Voltage 3.36 V 3.63 V 2.97 V 3.46 V 3.13 V
Current 6.52 mA 11.80 mA 4.00 mA 10.80 mA 5.00 mA
Tx Power -2.73 dBm 1.70 dBm -13.00 dBm -1.30 dBm -9.00 dBm
Rx Power N/A -- 3.00 dBm -15.90 dBm 0.00 dBm -11.90 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
san-sw01#
FrankN
Check the type of SFP on the FC target adapters in the A250s. They should be shortwave transceivers to match the Cisco DS-SFP-FC16G-SW.
