ONTAP Hardware
Node Create failed : ONTAP Select
vincentchase
Hello, I'm trying to deploy a single node Cluster (with evaluation license) ontap select 9.2 on ESX 5.5 (udape 3) with SAN disks (HP 3PAR) The node deployment failed with the following message : "NodeCreateFailed: Node "chgvavnapt21" create failed: Error during configuration of vnics: InvalidRequestFault." I would appreciate it if someone can help me.
1 ACCEPTED SOLUTION
2 REPLIES 2
vincentchase
Thank you. appreciate the help.
