ONTAP Hardware
Properly unfailling a disk
MOHAMED_DIALLO
hi everyone i am new to this site and a little experience in NetApp so please bare with thank you.
Actually i had a failed disk which i was able to unfail but my problem is its still showing in the filerview as fail. so my question is how do let the filerview see it as normal because from the command line it is no longer seen as fail.
Thank you
6 REPLIES 6
DOMINIC_WYSS
strange thing, so more questions:
-which ontap version do you have? (as you mention filerview, it will be old!)
-which commandline do you use to see the failed disk?
-what's the output of sysconfig -r ?
MOHAMED_DIALLO
Thank you for ur reply Dominic
the version is:NetApp Release 8.0.2RC1 7-Mode
fas6210ca> sysconfig -r
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active, pool0)
    RAID group /aggr0/plex0/rg0 (normal)
      RAID Disk Device          HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   5a.10.0         5a    10  0   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
      parity    5a.11.0         5a    11  0   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
      data      5a.10.1         5a    10  1   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
Pool1 spare disks (empty)
Pool0 spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           5a.10.4         5a    0   12  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.3         5a    10  3   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.5         5a    10  5   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.6         5a    10  6   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.7         5a    10  7   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.8         5a    10  8   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.9         5a    10  9   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.10        5a    10  10  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.13        5a    10  13  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.14        5a    10  14  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.15        5a    10  15  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.16        5a    10  16  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.19        5a    10  19  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.20        5a    10  20  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.21        5a    10  21  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.22        5a    10  22  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.23        5a    10  23  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.2         5a    11  2   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.3         5a    11  3   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.4         5a    11  4   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.5         5a    11  5   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.6         5a    11  6   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.7         5a    11  7   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.8         5a    11  8   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.9         5a    11  9   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.10        5a    11  10  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.12        5a    11  12  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.13        5a    11  13  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.14        5a    11  14  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.15        5a    11  15  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.16        5a    11  16  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.21        5a    11  21  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.22        5a    11  22  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.11.23        5a    11  23  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688 (not zeroed)
spare           5a.10.2         5a    10  2   SA:B   0  SAS  15000 560000/1146880000 560879/1148681096 (not zeroed)
spare           5a.11.17        5a    11  17  SA:B   0  SAS  15000 560000/1146880000 560879/1148681096
Broken disks
bad label       5a.11.1         5a    11  1   SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
Partner disks
partner         1a.01.23        1a    1   23  SA:B   0  SAS  15000 0/0               560879/1148681096
partner         1a.02.13        1a    2   13  SA:B   0  SAS  15000 560000/1146880000 560879/1148681096
partner         1a.01.12        1a    1   12  SA:B   0  SAS  15000 560000/1146880000 560879/1148681096
partner         1a.00.23        1a    0   23  SA:B   0  SAS  15000 560000/1146880000 560879/1148681096
partner         1a.00.12        1a    0   12  SA:B   0  SAS  15000 560000/1146880000 560879/1148681096
partner         1a.00.14        1a    0   14  SA:B   0  SAS  15000 0/0               560879/1148681096
partner         1a.00.11        1a    0   11  SA:B   0  SAS  15000 0/0               560879/1148681096
partner         1a.00.18        1a    0   18  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         5a.11.11        5a    11  11  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.10.12        5a    10  12  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.11.20        5a    11  20  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.11.19        5a    11  19  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.11.18        5a    11  18  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.10.11        5a    10  11  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         5a.10.18        5a    10  18  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         5a.10.17        5a    1   12  SA:B   0  SAS  15000 560000/1146880000 560208/1147307688
partner         1a.02.7         1a    2   7   SA:B   0  SAS  15000 0/0               560879/1148681096
partner         1a.00.9         1a    0   9   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.6         1a    0   6   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.16        1a    2   16  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.4         1a    2   4   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.3         1a    2   3   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.23        1a    2   23  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.18        1a    1   18  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.8         1a    2   8   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.21        1a    1   21  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.16        1a    1   16  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.8         1a    1   8   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.14        1a    2   14  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.10        1a    1   10  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.7         1a    1   7   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.8         1a    0   8   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.18        1a    2   18  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.17        1a    1   17  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.19        1a    0   19  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.19        1a    1   19  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.13        1a    1   13  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.4         1a    0   4   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.5         1a    0   5   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.1         1a    1   1   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.1         1a    2   1   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.7         1a    0   7   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.11        1a    2   11  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.21        1a    0   21  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.15        1a    2   15  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.1         1a    0   1   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.3         1a    1   3   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.4         1a    1   4   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.22        1a    0   22  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.20        1a    1   20  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.14        1a    1   14  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.10        1a    0   10  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.9         1a    1   9   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.22        1a    1   22  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.20        1a    0   20  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.16        1a    0   16  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.12        1a    2   12  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.3         1a    0   3   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.17        1a    0   17  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.21        1a    2   21  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.10        1a    2   10  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.2         1a    2   2   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.6         1a    1   6   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.22        1a    2   22  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.11        1a    1   11  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.5         1a    1   5   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.15        1a    1   15  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.2         1a    0   2   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.19        1a    2   19  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.13        1a    0   13  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.9         1a    2   9   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.17        1a    2   17  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.2         1a    1   2   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.0         1a    2   0   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.20        1a    2   20  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.15        1a    0   15  SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.5         1a    2   5   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.00.0         1a    0   0   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.02.6         1a    2   6   SA:B   0  SAS  15000 0/0               560208/1147307688
partner         1a.01.0         1a    1   0   SA:B   0  SAS  15000 0/0               560208/1147307688
gloghn-fas6210ca>
gloghn-fas6210ca>
aborzenkov
Well, you have one broken disk. Try “disk unfail -s 5a.11.1” (not sure if this is supported in your version).
MOHAMED_DIALLO
it worked dominic, thanks.
gloghn-fas6210ca>
gloghn-fas6210ca> priv set advanced
Warning: These advanced commands are potentially dangerous; use
         them only when directed to do so by NetApp
         personnel.
gloghn-fas6210ca*>
gloghn-fas6210ca*>
gloghn-fas6210ca*>
gloghn-fas6210ca*> disk unfail -s 5a.11.1
disk unfail: unfailing disk 5a.11.1...
gloghn-fas6210ca*> Thu Aug 28 12:15:16 GMT [gloghn-fas6210ca: raid.disk.unfail.done:info]: Disk 5a.11.1 Shelf 11 Bay 1 [NETAPP   X412_S15K7560A15 NA04] S/N [6SL118B50000N14402BL] unfailed, and is now a spare
gloghn-fas6210ca*>
gloghn-fas6210ca*>
DOMINIC_WYSS
now you should zero out the disk:
disk zero spares
and update Ontap! your version is very old and it is a release candidate! (rc1)
go for Ontap 8.1.4P4 or 8.2.1P2
MOHAMED_DIALLO
Thank you Dominic
will do that later
