ONTAP Hardware
Quota (and quota report) not working
JEREMY_CLUZEL
Hi,
I have a strange problem on my filer.
I created a Qtree "test" on a volume "VOLUME".
I also defined a "user quota" of 1GB/user and with a threshold of 800MB.
I checked the "/etc/quotas" file:
#Auto-generated by setup Fri Jun 29 17:36:20 GMT 2012
*       user@/vol/VOLUME/test     1048576K        -       819200K -       -
and everything seems OK.
But, the quota doesn't seem to apply. Moreover, the "quota report" command doesn't even show that the quota applies:
FAS2240> quota report /vol/VOLUME/test/JCL/File_1.exe
                                 K-Bytes             Files
Type       ID    Volume    Tree  Used      Limit     Used    Limit   Quota Specifier
quota: no quota for file /vol/VOLUME/test/JCL/File_1.exe.
Do I miss something ?
Thanks,
Regards,
Jeremy
1 ACCEPTED SOLUTION
James_Littlefield
You might want to turn off quotas on this volume and than turn them back on to force a "rebuild". running "quota status" will let you know when the quota rebuild has been completed.
5 REPLIES 5
James_Littlefield
Did you remember to turn quotas on this volume ("quota on VOLUME")?
JEREMY_CLUZEL
Yes, quotas are already enabled on this volume.
They even seem to be effective on another qtree. FYI this another qtree is listed when I do a "quota report" command.
James_Littlefield
ogra
Well you are correct with the steps. However, if you haven't restarted the Quota services then the new change in the file will not come into effect.
JEREMY_CLUZEL
James.Littlefield was right.
Thanks for all.
Regards,
Jeremy
