ONTAP Hardware
Recommendation for Raid Groups for lots of disk
peter1965
Hi -
in our environment we have a 6280 san and we use Commvault to back data from the 6280 to our v6210. We recently purchased a lot of 2TB disk that are not assigned to any aggrs yet and I am anxious to get my mits on those disks and start re-engineering our current setup and was curious what raid group size I should do. I think (not 100% sure) that Commvault requires at least 7 disks per raid group.
My assumption - is more spindles the better ? As the i/o this helps the i/o reads.
Anyhow I have a 132 spare 2tb disks on controller a.
and 156 spare 2tb disks on controller b. these disks are right sized at 1.62 TB
and these sans are on 10GbE network. So what are your guys thoughts for best performance and usage of disk for nice sized aggrs as I would create 5tb volums with qtrees and cifs share for Commvault to write the data to.
1 ACCEPTED SOLUTION
radek_kubka
Ah, sorry - now I see what's going on!
8.1.x - 162TB limit is across the board the same for all 6200 series boxes (& 6070 & 6080)
8.0.x - 100TB limit for 6240 & 6280, but only 70TB for 6210!
So in fact you are looking at recommended max aggregate layout of:
- 40 spindles = 2x 20-spindles RG
16 REPLIES 16
thomas_glodde
Hi there,
please refer to TR 3838 Storage Subsystem Configuration Guide about the general limitations considering raidgroup size, max aggr size of your ontap etc.. Commvault usualy does not have a direct requirement how the underlying raid layout should be.
As i imagine Commvault is causing a large sequential load on your disks you can go for bigger raidgroup sizes.
For S-ATA, default is 14, max is 20. You might want to stay between 16 and 18. On a NetApp machine its usualy the best idea to create the biggest aggr possible or, if not all disks fit into 1 aggr, create 2 even layouted aggregates and create 2 volumes for Commvault to backup into.
Kind regards,
Thomas
peter1965
@thomas – thanks.
Commvault wants 5TB cifs shares as that is what is supported by their support team etc. Appreciate the info.
peter1965
Since I balanced the number disks on each controller of the v6210 I have 144 on each at my disposal.
To maintain a balanced raid group design these seem to be my options unless someone can correct me. Bear in mind this san is used for D2D purposes and the disks are 2TB SATA Netapp disk which are right sized to ~1.62 TB.
Even though I like option B but it uses all the disks leaving me with no hot spares. So that leaves me with option A or C. Option C provides more usable space but what about the r/w performance? Perhaps I am splitting hairs in this case. Option A or C leaves me with a total of 8 hot spares when combining both controllers.  I just need to go with one of the two options and move on… Thoughts ☺
Option            Disk Count      RG     USABLE Space (TB)
A                       140             14       174.63
B                       144             18       186.27
C                       140             20       183.36
niels
Hi Peter,
you're talking V-Series on the one hand and "disks" on the other.
Are you trying to create aggregates from
a) physical NetApp disks attached to a V-Series controller, or
b) LUNs from a 3rd-party array that happen to be 2TB in size?
Generally go with the defaults.
For a) it's 14 disks per RAID-DP Raid Group
This can be increased to 16 so as an example you could go with the following:
- for 132 disks that would result in 8 Raid Groups with 16 disks and 4 spares (~181 TB usable)
- for 156 disks that's 10 RGs with 15 disks and 6 spares (~210 TB usable)
For b) the default RG size is 8 but has no special meaning as there is no raid calculation for 3rd-party LUNs, just a RAID0 striping. The RG size doesn't have any effect on this and spares are not required - well, at least not of that size.
regards, Niels
peter1965
@neils
Thanks for your reply . After I send my post off to the forum I went into the vseries and balanced out the disks so they are now even on both controllers. My request has to do with recently new purchased netapp disk on the filer. There only used to be one disk shelf but now many 2tb drive shelves.. Current aggrs are from an IBM San that are presented via LUNS.
Since I balanced the disks of 144 available on each controller I can create a big aggr which would leave me 8 spares in total. Always good to have spares. I just want to make sure from a read/write performance that this setup would be optimum. Also this would be a 64bit aggr with RAID-DP
radek_kubka
There is 162TB limit for the aggregate size on 6000 series systems with ONTAP 8.1 (it's 100TB for 8.0.x)
As per the TR-3838, this is the recommended layout for a max size aggregate with 2TB drives:
- 112 spindle count = 7x 16-spindle RAID group
Regards,
Radek
peter1965
So you are saying my initial thoughts are defunct ? ☹ My hope for one aggr with all those disks may not be a reality after all..
p.s.
I am running data ontap version 8.02SP3
radek_kubka
So this is the recommended layout for a 100TB aggregate:
- 68 spindle count = 4x 17-spindle RAID group
peter1965
Not sure if you meant usable but that would be about 87TB usable. Sigh. so I need to break this out evenly to not waste disk for this d2d solution
peter1965
Hmm –
peter1965
Since you mentioned I can do 112 spindles that still didn’t work - so I figured perhaps the total size had to be under 100tb.. so here is another try.. I wonder what the heck I have going on that is wrong.
radek_kubka
peter1965
Thanks for the clear up. I assume the rg of 20 is good performance etc?
radek_kubka
That's a bit tricky question.
Big RAID group is absolutely fine performance-wise when serving data. However, RAID rebuild will take longer than for a smaller group. On the other hand, with minimum 2 hot-spares per head, you have so called Drive Maintenance, which will aim to replace a drive before it fails (by monitoring a number of errors) - in this case there is no RAID rebuild, just a copy operation.
At the end of the day, 2x 20-disks RAID group aggregate is what NetApp recommends in this particular scenario as the best practice.
peter1965
What about 48 disks to give me 16 disk raid group X 3
That will give me 61 TB usable versus the 40 disk layout with 20 disk rg X 2 @ usable space of almost 53TB ??
radek_kubka
Yep, this is fine as well. It will mean bigger aggregates, but maybe more overhead due to smaller RAID groups (you need to do the maths across all drives, not just a single aggregate - it's a bit of a puzzle I must admit )
