ONTAP Hardware
Replacing FAS 2040R5 Controller
amitkeshani
To Experts,
Following are the  errors I encountered upon replacing a  FAS 2040 Controller,
Upon autoboot  of the newly replaced controller I got the following error
    * Autoboot of primat_image failed. File not found (-18)
Then I performed the follow steps in-order to bring the controller up
1. First performing boot_diags on loader results into following error
LOADER-B> boot_diags
Could not load fat://boot0/X86/diag/kernel fat://boot0/X86_ELF/diag/diag.krn: Fi le not found
2. Secondly i tried performing a netboot using tftp server, it results into following error
LOADER-B> netboot tftp://192.168.1.1/734_netboot.e
Loading 192.168.1.1/734_netboot.e:Failed: Timeout occured Could not load tftp://192.168.1.1/734_netboot.e: Timeout occured
*** command status = -21
The reason i am doing this is to boot into maintenance mode and get the system id, and  reassign those disks again.
on the other hand,on test basis i ran this command
LOADER-B> boot_primary
Could not load fat://boot0/X86/freebsd/image1/kernel fat://boot0/X86_ELF/kernel/
primary.krn: File not found
*** command status = -18
All it reports is kernel error
Please advise a way forward
1 REPLY 1
bhanojiisit
