ONTAP Hardware
Script to create volume on NAS
mpileye
Hello,
I'm trying to automate NetApp volume creation.
For it I use Powershell Dataontap toolkit (4.6).
Everythings work except setting volume option maxdirsize.
When I try through SSH with command vol options <vol_name> maxdirsize XXXXXX it ask me for confirmation.
When I try through PS with command Set-NaVolOption -Name <vol_name> -Key maxdirsize -Value XXXXXX it make several minute before crash...
Is there a way to :
- Disable confirmation with SSH command ?
or
- Make powershell command works ?
My environnement is :
FAS8020 in NetApp Release 8.2.3P6 7-Mode
Thanks 🙂
1 REPLY 1
AlexSun0302
-confirm:$false, try it, in the powershell
