ONTAP Hardware
Snapvault -- idle with restart checkpoint
NEWNETAPP987
Hello,
I am new to NetApp Snapvault.
I have one volume that will start transferring, then it stops with " Idle with restart Checkpoint"
I did snap vault start.   It started to transfer but then it stopped again.
What do I need to do to complete the snapvault?
Thanks,
4 REPLIES 4
JGPSHNTAP
First, are you using oncommand or just doing this via the CLI
Also, check the snapmirror log in /etc/log to see what it says
NEWNETAPP987
I am doing with via the CLI.
For some reason, the snapmirror log is not recording any messages.
JGPSHNTAP
Ok, CLI = good IMHO
Are you snapvaulting off a mirror or just a normal volume
NEWNETAPP987
I was able to fix this.  The volume had run of of space.
