ONTAP Hardware
Stuck HDD
denniswier
Hi,
I own a old DS14 MK2 AT shelf, and have runinto the problem that one of the drivesleds is stuck.
the lever screeces open and close, and i can pull aprox 1cm uit of the shelf, but it hinges in i guess, the inner latch (teeth)
is there a way or removing any stuck drives?
or is it a peel apart action, and just buy an replacing sled?
1 REPLY 1
Sahana
Hi,
1 Ground yourself to the system chassis using the grounding leash.
2 To remove the disk, press down on its release mechanism with one hand while grasping the top flange of the disk shelf with the other hand.
3 Gently slide the disk out until it disengages
Reference: https://library.netapp.com/ecm/ecm_get_file/ECMM1280273 page 31 Remiving a disk
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
