ONTAP Hardware
Supported SFP for FAS8700
Ebo_Hagan
Hi All, we recently acquire FAS8700 HA system. The network we have is 1GB and 10GB. The onboard ethernet ports are 25GbE/100GbE (ROCE). Can I install either a 1GB or 10GB SFPs into the onboard ethernet ports and configure for snapmirror??
Thank you in advance.
Regards
1 ACCEPTED SOLUTION
andris
Yes, NetApp Hardware Universe is your friend for these types of questions... check the "Onboard Ports & Cables" link in the results.
But be aware that the onboard ports on FAS8700 are reserved for internal use in most cases.
e0a/e0b (25GbE) are for HA cabling.
e0c/e0d (40/100GbE) are for cluster network cabling.
If you have the Ethernet bundle variant, the e0e -> e0h 10/25GbE Mezzanine ports can provide your connectivity for data or SnapMirror.  If you have the FC bundle variant, you'll need to acquire suitable NICs for one of your PCIe slots.
3 REPLIES 3
hmoubara
Hello,
You can always verify SFP supportability via the link below:
https://hwu.netapp.com/Home/Index
Thanks
andris
pedro_rocha
yeah check the hwu
e0e-e0h can have 1 and 10GbE transceivers
