ONTAP Hardware
Tool for Analysing Data
biescas
Hi,
Can you help with the following question from one of our Partners?
"I’ve just collected virtualisation collection data that has been running for 7 days, is there any other way of viewing or analysing the data other than the startanalyzerUI java script? I thought there was a Netapp tool that could give more detail from the collected data or even recommend a suitable FAS array or am I mistaken?"
Regards,
3 REPLIES 3
CCOLEMAN_
i'm a little confused on what tool was used to collect the data?
biescas
The virtualization data collector tool with jre.
radek_kubka
Hi Elias,
Personally I haven't used this tool, but I believe these are the steps:
1) Collection via Virtualization Data Collector
2) Results processed by Virtualization Data Analyser
3) Output from step 2) used for actual sizing with Custom Application Sizer
Regards,
Radek
