ONTAP Hardware
FAS2020 Boot issues
KARLOCHACON
hi guys
I doing some changes/configurations on this FAS2020 using setup conmmand the issue is every time a reboot one of the filer is stuck at this menu:
(1)  Normal boot.
(2)  Boot without /etc/rc.
(3)  Change password.
(4)  Initialize owned disks (6 disks are owned by this filer).
(4a) Same as option 4, but create a flexible root volume.
(5)  Maintenance mode boot.
the other filer boots up ok
what could be the issue?
thanks a lot
2 REPLIES 2
KARLOCHACON
no worries guys
I fixed it..... I went into Maintenance Mode (5)
and run boot_primary boot OK after that I run again reboot and boots up OK like filer2
thanks a lot
aborzenkov
This normally happens when filer cannot find its root volume. If you post full log from turning power on until this menu appears, someone may be able to tell what happens.
