ONTAP Hardware
What is the procedure to get the Sysconfig-A output for “V” Series Systems ?
ashritha
Thanks in advance!!
Ashrita.
1 REPLY 1
rohithsgowda
Vseries would use Data Ontap as any other FAS filers, you could login to the console via telnet or ssh and then use the command "sysconfig -a" to get the output
