ONTAP Hardware
advise on synch mirror
GUVNIJJAR
I am trying to understand synchmirror, and trying to understand the term array luns.  How do define array luns, are they just raid groups, or disk groups.
Also the term storage arrays.  I read this terms in the netap manuals.  I just want to understand the terms.
Also in synchmirror it talks about 2 plexes, one local and one remote.   Is the local one, the current one which is the existing data, and the remote one is the mirror copy.
Any advise
1 REPLY 1
radek_kubka
Hi,
I think you took it from V-series documentation (gateway product), where it refers to 3-party arrays virtualised by NetApp controllers.
Well, I think this is coming from MetroCluster setup - local plex is the active copy (read/write) & the remote is the passive one (read-only).
Regards,
Radek
