ONTAP Hardware
fcp initiator group (not logged in)
deygaurab
Hello,
Recently I have added an fcp initiator (wwpn) to an exisiting igroup. after adding , I do not see it as "logged in".. The zoning is good.. Do we need to change some setting or add both the initiators in the igroup together as a best practice.?
    IG_aixsaptst (FCP):
        OS Type: aix
        Member: c0:50:76:03:e8:aa:00:4c (logged in on: vtic, 0d, 1d)
        Member: c0:50:76:03:e8:aa:00:52 (not logged in)
        UUID: 50aed88c-c6a6-11e1-ae2b-00a09820168b
        ALUA: Yes
zone config:
* fcid 0x0c0200 [pwwn 50:0a:09:87:8f:6f:95:82]
* fcid 0x0c0300 [pwwn 50:0a:09:86:8f:6f:95:82]
* fcid 0x0b0027 [pwwn c0:50:76:03:e8:aa:00:52]
any ideas anyone?
Regards
1 ACCEPTED SOLUTION
radek_kubka
I'd say the missing step is rescanning on the host.
5 REPLIES 5
radek_kubka
Hi,
Is the pwwn correct? Did you rescan disks / hba on the host after adding initiator to igroup?
Regards,
Radek
deygaurab
Hi Radek,
Thanks for the response.  Yes the pwwn correct on the switches.. Is rescanning required on the host side ?
The host is already seeing the LUN over a single path. I added a redundant path today with the other initiator of the host on the other fabric.
  IG_aixsaptst (FCP):
        OS Type: aix
        Member: c0:50:76:03:e8:aa:00:52 (not logged in)------- redundant initiator of the host which I added
        ALUA: Yes
zone config:
* fcid 0x0b0027 [pwwn c0:50:76:03:e8:aa:00:52]------ redundant initiator of the host..
The zoning and pwwn looks fine. Is there something I have missed after adding the initiator to the igroup?
The sequence I added it are:
1. Zoning on the switch.
2.Add the initiator to the existing igroup
Regards
Rahul
radek_kubka
deygaurab
Thanks Radek, I will try and let you know.
deygaurab
Hello Radek,
Rescanning on the host worked. Both the initiators in the igroup is showing as logged in .. Many thanks for your help.
Cheers
Rahul
