ONTAP Hardware
how to find Disk Shelf Firmware for FAS2240-2 for DS2246
tgottenoef
Hello,
how can I find the latest Disk Shelf Firmware for FAS2240-2 for DS2246 shelf. the Matrix is very confusing for FAS2xxx.
after upgrade to 8.2.3P3 7-Mode , autosupport risks show me that I dont use the latest Firmware.
my data after upgrade:
> sysconfig -v
NetApp Release 8.2.3P3 7-Mode: Tue Apr 28 14:48:22 PDT 2015
System ID:
slot 0: System Board 1.7 GHz (System Board XIX D2)
Model Name: FAS2240-2
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
Firmware rev: 01.12.06.00
Base WWN: 5:00a098:001c548:f0
Phy State: [0] Enabled, 6.0 Gb/s
[1] Enabled, 6.0 Gb/s
[2] Enabled, 6.0 Gb/s
[3] Enabled, 6.0 Gb/s
ID Vendor Model FW Size
00.0 : NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.1 : NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.2 : NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.3 : NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.21: NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.22: NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
00.23: NETAPP X422_TAL13600A10 NA01 560.0GB (1147307688 520B/sect)
Shelf 0: DS2246 Firmware rev. IOM6E A: 0153 IOM6E B: 0153
best regards
Thomas
4 REPLIES 4
aborzenkov
As always: Disk Shelf Firmware
tgottenoef
Thanks a lot ....
N/AIOM6E,SAS,6Gb,R6FAS22XX systems
FAS3XXX systems
FAS6XXX systems
FAS8XXX systems
IOM6E.0153.SFWIOM6E Firmware rev 01530153 FW fixes Bug 805767
0142 FW fixes Bug 719423
0131 FW fixes Bug 661043
0121 FW fixes Bug 607817
0113 FW fixes Bug 554317
01-AUG-14
wy did I get the risk warning in ASUP my FW is not at the latest version?
aborzenkov
This could well be an ASUP bug (it happened in the past). Open case with NetApp and ask them to verify.
tgottenoef
thanks a lot, a will do so.
Thomas
