ONTAP Hardware
how to reassign disks
CCOLEMAN_
Hello,
I have added a DS4243 with 24 1TB drives to my FAS2040.
It looks like the disks on my new shelf have already been assigned before. Anytime I try to do a disk_removeownership or disk_unassign it says this can only be done in maintenance mode?
How can I unassign and reassign the disks with out taking the filer down? (I only have one controller)
Thanks!
1 ACCEPTED SOLUTION
RodrigoNascimento
Hello,
Try this:
Identify the actual sysid owner:
> disk show
Remove the ownership using disk assign:
> disk assign <disk_id> -o unowned -s <sysid>
Regards,
Nascimento
NetApp - Enjoy it!
27 REPLIES 27
mlroberts99
It looks as though you have no spare disks in raid group 0, would you be able to copy the output of 'sysconfig -r'?
rmontavonsa
Of course, you can find the result of the command here:
Aggregate aggr0 (online, raid_dp) (block checksums)
  Plex /aggr0/plex0 (online, normal, active, pool0)
    RAID group /aggr0/plex0/rg0 (normal)
      RAID Disk Device          HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks        )    Phys (MB/blks)
      dparity   0c.00.1         0c    0   1   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      parity    0c.00.3         0c    0   3   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.5         0c    0   5   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.0         0c    0   0   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.7         0c    0   7   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.8         0c    0   8   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.10        0c    0   10  SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.6         0c    0   6   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.4         0c    0   4   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.9         0d    1   9   SA:A   0  SAS  15000 272000/557056        000  274845/562884296
Pool1 spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           0d.01.18        0d    1   18  SA:A   1  SAS  15000 272000/557056        000  274845/562884296
spare           0d.01.5         0d    1   5   SA:A   1  SAS  15000 272000/557056        000  280104/573653840
Pool0 spare disks
spare           0c.00.9         0c    0   9   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
spare           0c.00.11        0c    0   11  SA:A   0  SAS  15000 272000/557056        000  280104/573653840
Partner disks
partner         0d.01.6         0d    1   6   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0c.00.2         0c    0   2   SA:A   0  SAS  15000 272000/557056        000  280104/573653840
partner         0d.01.21        0d    1   21  SA:A   0  SAS  15000 272000/557056        000  274845/562884296
partner         0d.01.19        0d    1   19  SA:A   0  SAS  15000 0/0        274845/562884296
partner         0d.01.0         0d    1   0   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.10        0d    1   10  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.20        0d    1   20  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.4         0d    1   4   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.13        0d    1   13  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.17        0d    1   17  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.12        0d    1   12  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.8         0d    1   8   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.3         0d    1   3   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.11        0d    1   11  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.2         0d    1   2   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.7         0d    1   7   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.14        0d    1   14  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.1         0d    1   1   SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.22        0d    1   22  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.15        0d    1   15  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.16        0d    1   16  SA:A   0  SAS  15000 0/0        280104/573653840
partner         0d.01.23        0d    1   23  SA:A   0  SAS  15000 0/0        280104/573653840
mlroberts99
That's great,
To me, it looks like the below disk should not be assigned to the partner node but the node you took the 'sysconfig -r' from.
Try removing the ownership and assigning it again,
rmontavonsa
Ok, thank you for your answer !!!
Im not sur if i have all understand. I don't know what's a partner disk.
With the command sysconfig -r, we can see the disk is used. if i remove the ownership of this disk. I don't loose data ?
Sorry if my question is stupid, but it's the first time i work on a netapp system.
And if i remove the ownership of this disk, do you know what's the command line for assigning it again this partner disk ?
mlroberts99
A partner disk is a disk that is owned by the partner node in the HA pair. Im not too sure, it all depends on the the partner node, would you be able to run a 'sysconfig -r' on the other controller too?
rmontavonsa
of course, here you have the result of the command sysconfig -r on the other controller
> sysconfig -r
      dparity   0d.01.22        0d    1   22  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      parity    0d.01.1         0d    1   1   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.2         0d    1   2   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.3         0d    1   3   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.4         0d    1   4   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.6         0d    1   6   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.0         0d    1   0   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.7         0d    1   7   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.8         0d    1   8   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.21        0d    1   21  SA:B   0  SAS  15000 272000/557056        000  274845/562884296
      data      0d.01.20        0d    1   20  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.11        0d    1   11  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.12        0d    1   12  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.13        0d    1   13  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.14        0d    1   14  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.15        0d    1   15  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.16        0d    1   16  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.17        0d    1   17  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0c.00.2         0c    0   2   SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.10        0d    1   10  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.23        0d    1   23  SA:B   0  SAS  15000 272000/557056        000  280104/573653840
      data      0d.01.19        0d    1   19  SA:B   0  SAS  15000 272000/557056        000  274845/562884296
Pool1 spare disks (empty)
Pool0 spare disks (empty)
Partner disks
partner         0d.01.18        0d    1   18  SA:B   1  SAS  15000 272000/557056        000  274845/562884296
partner         0d.01.5         0d    1   5   SA:B   1  SAS  15000 272000/557056        000  280104/573653840
partner         0d.01.9         0d    1   9   SA:B   0  SAS  15000 272000/557056        000  274845/562884296
partner         0c.00.3         0c    0   3   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.4         0c    0   4   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.0         0c    0   0   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.7         0c    0   7   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.11        0c    0   11  SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.9         0c    0   9   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.6         0c    0   6   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.10        0c    0   10  SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.8         0c    0   8   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.1         0c    0   1   SA:B   0  SAS  15000 0/0        280104/573653840
partner         0c.00.5         0c    0   5   SA:B   0  SAS  15000 0/0        280104/573653840
rmontavonsa
Ok i have see the problem. We can see on the other controller pool0 and pool1 was empty. I have remove owner disk and reasign it from the other controller.
But i don't understand why i don't see the same pool0 and pool1 on the twoo controller. Now the status controller is "normal".
