ONTAP Hardware
message log on cDOT and 7 mode
Aras
How step for getting .txt log from cDot and 7-mode on FAS3210? can somebody explain it?
Thanks
2 REPLIES 2
hariprak
Hi,
The Service Processor Infrastructure (spi) web service is enabled by default to enable a web browser to access the log, core dump, and MIB files of a node in the cluster. The files remain accessible even when the node is down, provided that the node is taken over by its partner.
For more details on accessing a node's log, core dump, and MIB files by using a web browser refer below link,
https://library.netapp.com/ecmdocs/ECMP1368701/html/GUID-E593FD00-D062-4649-853A-4409E282FA12.html
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Aras
Hi,
Thanks for your respons,
but, how if I direct to the machine and using cli? can I using cp command and copy log from /mroot/etc/log/ to other location with output .txt extension file?
