ONTAP Hardware
not equal number of spares
lukasz_borek
Hi,
What can caouse such situation : FAS 3160 (A/A + syncmirror)
filerA> vol status -s
Pool1 sparedisks
RAIDDisk       Device  HA  SHELF BAY CHANPool Type  RPM  Used (MB/blks)    Phys (MB/blks)
Spare disksfor block or zoned checksum traditional volumes or aggregates
spare          2b.45   2b    2   13  FC:A  1  FCAL 15000 418000/856064000  420156/860480768
Pool0 sparedisks
spare          2a.61   2a    3   13  FC:A  0  FCAL 15000 418000/856064000  420156/860480768
filerB> vol status -s
Pool1 sparedisks
spare          1c.29   1c    1   13  FC:A  1  FCAL 15000 418000/856064000  420156/860480768
spare          1c.45   1c    2   13  FC:A  1  FCAL 15000 418000/856064000  420156/860480768
spare          1c.58   1c    3   10  FC:A  1  FCAL 15000 418000/856064000  420156/860480768
spare          2c.28   2c    1   12  FC:B  1  FCAL 15000 418000/856064000  420156/860480768
spare          2c.37   2c    2   5  FC:B   1  FCAL 15000 418000/856064000  420156/860480768
Pool0 sparedisks
spare          1d.29   1d    1   13  FC:A  0  FCAL 15000 418000/856064000  420156/860480768
spare          1d.45   1d    2   13  FC:A  0  FCAL 15000 418000/856064000  420156/860480768
spare          1d.61   1d    3   13  FC:A  0  FCAL 15000 418000/856064000  420156/860480768
spare          1d.77   1d    4   13  FC:A  0  FCAL 15000 418000/856064000  420156/860480768
spare          2d.76   2d    4   12  FC:B  0  FCAL 15000 418000/856064000  420156/860480768
filerA> vol status -f
Broken disks (empty)
filerB> vol status -f
filerA> disk show -v | grep -ifail
filerB> disk show -v | grep -ifail
1c.58       filerB(151707439)   FAILED 3QQ11KNX00009940GUDH [wtf?]
But :
filerA> disk show -v 1c.58
  DISK      OWNER                 POOL   SERIAL NUMBER
1c.58       filerB (151707439)   FAILED 3QQ11KNX00009940GUDH
filerB> disk show -v 1c.58
1c.58       filerB(151707439)   Pool1  3QQ11KNX00009940GUDH
My understanding was  that both nodes should have same spares visable? Why one filer shows disk 1c.58 as failed and second as healthy?
1 REPLY 1
Darkstar
I can only answer part of your question:
Each filer has its own spare disks. So it's perfectly normal to see different spare counts for each filer.
However, why the partner filer still thinkgs that 1c.58 is FAILED although the owning filer (filerB) sees the disk as working is beyond me. Maybe a simple "disk fail" followed by "disk unfail" (in diag mode) on filerB can resolve that issue. Otherwise I would open a case with NetApp if it bothers you too much. But as long as the owning filer sees the disk as usable (and not the other way round) it's normally not a problem
-Michael
