ONTAP Hardware
removing a disk: proper system ID is required for option -s
BITBUCKET
I'm trying to remove a shelf. All the disks on that shelf are spare disks. For starters I'm trying to unassign the disk by issuing the following command:
    disk assign -s 0a.01.0
Which fails issuing the following message:
Funny thing is that the following works fine:
    disk remove 0a.01.0
Which puts the disk on the broken disks pile. Doing the following returns the disk to the spare pool:
    priv set adanced
    disk unfail 0a.01.0
Why is my unassigning command failing?
1 ACCEPTED SOLUTION
aborzenkov
disk assign xx.xx -s unowned
1 REPLY 1
aborzenkov
