ONTAP Hardware
V-Series Brocade FMC - port based or WWN based zoning?
aborzenkov
Which one is supported/recommended? Documentation does not really say which one to use, just that which end devices should be put in the same zone.
Also IIRC Cisco does not even support port based zoning so I assume WWN zoning should at least be supported.
1 ACCEPTED SOLUTION
aborzenkov
Forget this. Just read
You must configure the zones using Domain IDs and port numbers; you cannot use the PWWN.
Case closed
1 REPLY 1
aborzenkov
Case closed
