ONTAP Hardware
sas admin
ANDY_MCKEE
Hi
I notice one of our stacks is reporting a problem with the cable.
Cable attached to SAS port "12d" is functioning in a degraded mode.
looking at sas admin expander. Both shelves show an disabled initatior. Is this something configurable or down to the faulty cable between the 2 shelves?
sasadmin expander 12d.1
WWN 500a09800008d3ff, ID 1, Serial Number '6000024290'
Manufacturer: Vendor 'NETAPP  ', Product 'DS224IOM6       ', Rev '0142', Level 2, Slot A
PHY[ 0/P0:0/T]: 6.0 Gb/s, Initiator 500a098000b25d60
PHY[ 1/P0:1/T]: 6.0 Gb/s, Initiator 500a098000b25d60
PHY[ 2/P0:2/T]: 6.0 Gb/s, Initiator 500a098000b25d60
PHY[ 3/P0:3/T]: Disabled
sasadmin expander 12d.2
WWN 500a09800009d13f, ID 2, Serial Number '6000024628'
Manufacturer: Vendor 'NETAPP  ', Product 'DS224IOM6       ', Rev '0142', Level 1, Slot A
PHY[ 0/P0:0/T]: 6.0 Gb/s, Expander 500a09800008d3ff
PHY[ 1/P0:1/T]: 6.0 Gb/s, Expander 500a09800008d3ff
PHY[ 2/P0:2/T]: 6.0 Gb/s, Expander 500a09800008d3ff
PHY[ 3/P0:3/T]: 6.0 Gb/s, Expander 500a09800008d3ff
PHY[ 4/P1:0/S]: 6.0 Gb/s, Initiator 500a098000ca725c
PHY[ 5/P1:1/S]: Disabled
PHY[ 6/P1:2/S]: 6.0 Gb/s, Initiator 500a098000ca725c
Thanks in advance
Andy
1 REPLY 1
korso
Andrew,
I would open a ticket with NetApp support as soon as possible, they have access to commands within sasadmin that can maullaually enable drive bay and available paths within the SAS stack.
