ONTAP Hardware
snapmirror error could not read from socket (error 13102)
soper_2010
Hi!
i have faced a problem with snappmirror.
we have 2 x fas2020 ontap 7.3.3, and snapmirror working fine in both directions
we have bought one FAS2240-2 and one Fas 2240-4 v.8.1.1.7 and snapmirror working fine in both directions
But when i set up a snapmirror from one fas2020 as source to a Fas2240-4 i got the error:
snapmirror.src.sockErr     Access denied for SnapMirror/SnapVault destination.
i looked at the host files and se there are no missmatch.
the options look like:
san1 (FAS2020)san2 (FAS2020)san4 (FAS2240-4)
snapmirror.access            host=san2
snapmirror.checkip.enable    on
snapmirror.delayed_acks.enable on
snapmirror.enable            on
snapmirror.log.enable        on
snapmirror.readahead         0
snapmirror.readahead_freq    0
snapmirror.vbn_log_enable    off
snapvalidator.version        9
snapmirror.access            host=san1
snapmirror.access            legacy (but if i set to lhost=san1 the result is the same)
snapmirror.checkip.enable    off
snapmirror.volume.local_nwk_bypass.enable on
snapmirror.vsm.volread.smtape_enable on
san4> snapmirror status
Snapmirror is on.
Source                     Destination                      State          Lag        Status
san1:Test_for_cifs    san4:test_second_snap  Uninitialized  -          Idle
san1 have a snapmirror.allow file and it look like:
san2
10.10.10.20
san2 have no snapmirror.allow file
san4 have no snapmirror.allow file.
Anyone have any idea what can be wrong?
Regards
Soran
1 ACCEPTED SOLUTION
soper_2010
Thanks again!
I solved it, changed options snapmirror.access to  legacy and it solved the problem.
The host file was correct and the dest.filer were defined in  snapmirror.allow
Soran
7 REPLIES 7
bsti
SAN4 needs to be in the snapmirror.allow file for SAN1.  Unless SAN4's IP is 10.10.10.20, then you will get the error your describe.
soper_2010
Thanks for answer!
now i put san4 to the snapmirror.allow file for SAN1 so it look as shown now! becouse i need both san2 and san4 to be able to sync the data with san1. the content of file was :
san2
10.10.10.20
and i put san4 int´a new line so it become:
san2
10.10.10.20
san4
10.10.10.44
and the result is the same, and get the same error.
bsti
Just to be certain, I don't think you want host names in your snapmirror.allow unless they are defined in your /etc/hosts.  Try this just to make sure:
SAN1 snapmirror.allow:
10.10.10.20  #  Assuming this is for SAN2
10.10.10.44  #  Assuming this is for SAN4
bsti
Another question:  Do you have any firewalls or routers between SAN1 and SAN4?  Can you verify something in the middle isn't stopping SM traffic between the two?
soper_2010
Thanks again!
Soran
pradkur
Yes , I faced the same issue your reply helped
Saranraj89
Hi All,
The same problem happens for me to initialize the new snapmirror relationship b/w two controllers ,but its not working the same error could not read from socket......any one came accross from this issue before.
