ONTAP Hardware
storage show disk
TDUBB1234
what does the below output tell me? how mnay shelves of disks?
> storage show disk -T
fDISK                  SHELF BAY SERIAL           VENDOR   MODEL      REV TYPE
0a.00.0                 0    0  HZ0AEELL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.1                 0    1  HZ0K9D3L         NETAPP   X302_HJUPI NA01 BSAS
0a.00.2                 0    2  HZ0JXYWL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.3                 0    3  HZ0KLHYL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.4                 0    4  HZ0JZEVL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.5                 0    5  HZ0KW7KL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.6                 0    6  HZ0KLMWL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.7                 0    7  HZ0JMKWL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.8                 0    8  HZ0K9D2L         NETAPP   X302_HJUPI NA01 BSAS
0a.00.9                 0    9  HZ0KW5PL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.10                0   10  HZ0KW84L         NETAPP   X302_HJUPI NA01 BSAS
0a.00.11                0   11  HZ0JZ5GL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.12                0   12  HZ0JYEZL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.13                0   13  HZ0KLJPL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.14                0   14  HZ0KLMAL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.15                0   15  HZ0JLRTL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.16                0   16  HZ0KW8TL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.17                0   17  HZ0KLNRL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.18                0   18  HZ0KLPXL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.19                0   19  HZ0JJUDL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.20                0   20  HZ0KLJGL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.21                0   21  HZ0KLGYL         NETAPP   X302_HJUPI NA01 BSAS
0a.00.22                0   22  HZ0KLYML         NETAPP   X302_HJUPI NA01 BSAS
0a.00.23                0   23  HZ0JZXRL         NETAPP   X302_HJUPI NA01 BSAS
2c.01.0                 1    0  WD-WCAW30938573  NETAPP   X302_WVULC NA00 BSAS
2c.01.1                 1    1  WD-WCAW30829619  NETAPP   X302_WVULC NA00 BSAS
2c.01.2                 1    2  WD-WCAW30837917  NETAPP   X302_WVULC NA00 BSAS
2c.01.3                 1    3  WD-WCAW30816240  NETAPP   X302_WVULC NA00 BSAS
2c.01.4                 1    4  WD-WCAW30939247  NETAPP   X302_WVULC NA00 BSAS
2c.01.5                 1    5  WD-WCAW30862565  NETAPP   X302_WVULC NA00 BSAS
2c.01.6                 1    6  WD-WCAW30802832  NETAPP   X302_WVULC NA00 BSAS
2c.01.7                 1    7  WD-WCAW30832885  NETAPP   X302_WVULC NA00 BSAS
2c.01.8                 1    8  WD-WCAW30939548  NETAPP   X302_WVULC NA00 BSAS
2c.01.9                 1    9  WD-WCAW30814902  NETAPP   X302_WVULC NA00 BSAS
2c.01.10                1   10  WD-WCAW30799754  NETAPP   X302_WVULC NA00 BSAS
2c.01.11                1   11  WD-WCAW30831082  NETAPP   X302_WVULC NA00 BSAS
2d.10.0                10    0  HZ0KHHKL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.1                10    1  HZ0LYNLL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.2                10    2  HZ0P2RZL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.3                10    3  HZ0LYJHL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.4                10    4  HZ0LZZZL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.5                10    5  HZ0LZ5JL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.6                10    6  HZ0M8WJL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.7                10    7  HZ0MG1DL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.8                10    8  HZ0MG2JL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.9                10    9  HZ0M7XKL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.10               10   10  HZ0LYYRL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.11               10   11  HZ0M8WDL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.12               10   12  HZ0KV9BL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.13               10   13  HZ0KNWXL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.14               10   14  HZ0KGTZL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.15               10   15  HZ0MG52L         NETAPP   X302_HJUPI NA01 BSAS
2d.10.16               10   16  HZ0M8VTL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.17               10   17  HZ0JDR7L         NETAPP   X302_HJUPI NA01 BSAS
2d.10.18               10   18  HZ0MGARL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.19               10   19  HZ0M7UEL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.20               10   20  HZ0LYV1L         NETAPP   X302_HJUPI NA01 BSAS
2d.10.21               10   21  HZ0M87TL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.22               10   22  HZ0JDERL         NETAPP   X302_HJUPI NA01 BSAS
2d.10.23               10   23  HZ0MG98L         NETAPP   X302_HJUPI NA01 BSAS
2a.11.0                11    0  WD-WMATV8784580  NETAPP   X302_WMARS NA06 BSAS
2a.11.1                11    1  WD-WMATV8739375  NETAPP   X302_WMARS NA06 BSAS
2a.11.2                11    2  WD-WMATV8737879  NETAPP   X302_WMARS NA06 BSAS
2a.11.3                11    3  WD-WMATV8738811  NETAPP   X302_WMARS NA06 BSAS
2a.11.4                11    4  WD-WMATV8779682  NETAPP   X302_WMARS NA06 BSAS
2a.11.5                11    5  WD-WMATV8735936  NETAPP   X302_WMARS NA06 BSAS
2a.11.6                11    6  WD-WMATV8738248  NETAPP   X302_WMARS NA06 BSAS
2a.11.7                11    7  WD-WMATV8738576  NETAPP   X302_WMARS NA06 BSAS
2a.11.8                11    8  WD-WMATV8784808  NETAPP   X302_WMARS NA06 BSAS
2a.11.9                11    9  WD-WMATV8739282  NETAPP   X302_WMARS NA06 BSAS
2a.11.10               11   10  WD-WMATV8738323  NETAPP   X302_WMARS NA06 BSAS
2a.11.11               11   11  WD-WMATV8738693  NETAPP   X302_WMARS NA06 BSAS
2a.11.12               11   12  WD-WMATV8779507  NETAPP   X302_WMARS NA06 BSAS
2a.11.13               11   13  WD-WMATV8739276  NETAPP   X302_WMARS NA06 BSAS
2a.11.14               11   14  WD-WMATV8735039  NETAPP   X302_WMARS NA06 BSAS
2a.11.15               11   15  WD-WMATV8739175  NETAPP   X302_WMARS NA06 BSAS
2a.11.16               11   16  WD-WMATV8739248  NETAPP   X302_WMARS NA06 BSAS
2a.11.17               11   17  WD-WMATV8738559  NETAPP   X302_WMARS NA06 BSAS
2a.11.18               11   18  WD-WMATV8739690  NETAPP   X302_WMARS NA06 BSAS
2a.11.19               11   19  WD-WMATV8738821  NETAPP   X302_WMARS NA06 BSAS
2a.11.20               11   20  WD-WMATV8738298  NETAPP   X302_WMARS NA06 BSAS
2a.11.21               11   21  WD-WMATV8706905  NETAPP   X302_WMARS NA06 BSAS
2a.11.22               11   22  WD-WMATV8739176  NETAPP   X302_WMARS NA06 BSAS
2a.11.23               11   23  WD-WMATV8738322  NETAPP   X302_WMARS NA06 BSAS
8 REPLIES 8
jakob_bena
hi,
you can see your attached shelves, with port and shelf id number. disk revision and serialnumber of your disks.
your system has 4 shelves. one is only half full.
TDUBB1234
what is the difference between
0a.shelf1
and
0a.shelf0
or
2c.shelf1 and 2c.shelf0
how many shelves do i have?
agireesh
“Storage show disk” command list the information about all the disk connected to your storage system. If you are using “-T” option then it’ll list type of disk (FCAL, BSAS etc) with extra column.
Regards,
Gireesh
jakob_bena
you have an internal sas connector, and one additional card in your system.
from your output i can see, that you have 1 shelf connected on your onboard port. 3 shelves are connected on your additional card.
one every sas connector you can add 10 shelves per stack. in the past we had loops with 6 shelves a 14 disks.
shelf 0 or shelf 10, is only the shelf id. you can change it like you want.
0a means, that your diskshelf is connected on your onboard sas port.
2a means, that your diskshelf is connected on a additional card (sas).
0 is everytime onboard device.
1, 2, ,3 .... and so on, is an additinal device. pci slots that you can use
TDUBB1234
what about this
for each shef looks it looks like this in filer view
what are the sqr0 cir and sil?
TDUBB1234
so the shelves that are connected to the sas card are 2c, 2d, and 2a? what happened to 2b? how many sas ports are there,
TDUBB1234
what do you mean change it anyway i like? what does that mean.
> storage show adapter -a
Slot:            0a
Description:     SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C)
Firmware Rev:    01.09.01.00
Base WWN:        5:00a098:0000c60:e0
State:           Enabled
In Use:          Yes
Redundant:       Yes
Phy State:       [0] Enabled, 3.0Gb/s (9)
                 [1] Enabled, 3.0Gb/s (9)
                 [2] Enabled, 3.0Gb/s (9)
                 [3] Enabled, 3.0Gb/s (9)
Slot:            0b
Description:     SAS Host Adapter 0b (PMC-Sierra PM8001 rev. C)
Base WWN:        5:00a098:0000c60:e4
State:           Disabled
In Use:          No
Redundant:       Yes
Phy State:       [0] Disabled (1)
                 [1] Disabled (1)
                 [2] Disabled (1)
                 [3] Disabled (1)
Slot:            2a
Description:     SAS Host Adapter 2a (PMC-Sierra PM8001 rev. C)
Base WWN:        5:00e004:000136e:68
State:           Enabled
In Use:          Yes
Redundant:       Yes
Slot:            2b
Description:     SAS Host Adapter 2b (PMC-Sierra PM8001 rev. C)
Base WWN:        5:00e004:000136e:6c
State:           Disabled
In Use:          No
Redundant:       Yes
                 [1] Disabled (1)
                 [2] Disabled (1)
                 [3] Disabled (1)
Slot:            2c
Description:     SAS Host Adapter 2c (PMC-Sierra PM8001 rev. C)
Base WWN:        5:00e004:000136e:60
State:           Enabled
In Use:          Yes
Redundant:       Yes
Slot:            2d
Description:     SAS Host Adapter 2d (PMC-Sierra PM8001 rev. C)
Base WWN:        5:00e004:000136e:64
State:           Enabled
In Use:          Yes
Redundant:       Yes
what can i tell from all these adapters? 6 total sas adapters.
jakob_bena
hi,
you can change the shelf id only on your shelf 😉 this is unique
your sas ports 0b and 2b are disable, maybe there are attached disk shelves. you can use it later....
