ONTAP Hardware
vSeries Panic when backend SAN failover
JOEYNGUYENHP
Hello All,
Not sure if anyone else experience this issue, but my backend SAN array failover and caused my vSeries cluster to panic and reboot.
Is there any way to avoid something like this? The backend is an EVA array.
thanks
joey
2 REPLIES 2
isaacs
Hi Joey,
Have you opened a support case with NetApp?  I highly recommend doing so.  This sounds like it may be a configuration issue, and our support engineers can help verify the configuration.
Thanks!
Dan Isaacs
V-Series TME
NetApp
JOEYNGUYENHP
can this be an Ontap bug?
