Object Storage
Maximum size for a ONTAP bucket in FAS8300 ONTAP 9.14.1 with FabricPool
Northman
I have been searching and googling and also checking HWU, but cannot find it.
A bucket consists of a FlexGroup, which again consits of one or more flex volumes. For FAS8300, ONTAP 9.14.1, the max volume size is 300 TB and the max object size is 16 TB. But what is the maximum size for one bucket?
1 ACCEPTED SOLUTION
Abeltran
Hello Northman,
I you check on the "Detailed Matrix", you can choose "Maximum Size of the Bucket (PB)".
Kind regards,
Albert
4 REPLIES 4
SpindleNinja
it's in HWU.  Look for "S3 Cluster limits"
Northman
I did not see it there? I want to know the maximum size for a bucket , not the maximum number of buckets etc.
Abeltran
Hello Northman,
Kind regards,
Albert
Northman
Thanks. Also, I selected a config for MEtrocluster, which is wrong, so it showed "N/A"
