SQL query format help
cscott
Hi,
     I need to refine an SQL query and have not been able to find syntax that appears to work.
Use Case:
In a workflow an admin selects a controller name from a drop-down
     mysite1nodeA
     mysite1nodeB
     mysite2nodeA
     mysite2nodeB
Farther down in the workflow the admin must select a dataset and I need to refine it as too many volumes get put in the first returned.
For any given frame I will have two possible datasets, i.e.:
     mysite1nodeA_7_35
     mysite1nodeB_7_35
     mysite2nodeA_7_35
     mysite2nodeB_7_35
     mysite1node_0_35
     mysite2node_0_35
So selecting mysite1nodeA should be able to return - mysite1nodeA_7_35 or mysite1node_0_35
using this I can get mysite1node as part of the query, but I cannot determine where(or if possible) to place the wild card to match the rest of the dataset name, so I get no result.  In lab testing, creating a dataset named mysite1node returns, so the query as it stands is valid, just not what I need.
SELECT
    DISTINCT dataset.name
FROM
    storage.dataset
WHERE
    dataset.name like substr('${src_array}',1,LENGTH('${src_array}')-1)  <-- returns the controller name minus the A or B, but I have not been able to place the required "%" that will actually match the dataset.
    AND dataset.name NOT LIKE '%_drive'
    AND dataset.name NOT LIKE 'SnapMirrorLag'
    AND dataset.dfm_name LIKE '${pm_dfm}'
ORDER BY
    dataset.name
Any ideas for something other than my very basic SQL query capabilities would be greatly appreciated,
-Scott
2 REPLIES 2
cscott
Ok, this is not really what I want and probably not efficient, but it greatly reduces the number of datasets.  I would still welcome a better way to do it.
AND dataset.name LIKE concat(trim(trailing 'a' from '${src_array}'),'%')
OR dataset.name like concat(trim(trailing 'b' from '${src_array}'),'%')
cscott
Does what I need, for those who are unaware "_" is a special character for the SQL query, I had to escape it with "\"
AND dataset.name LIKE concat(trim(trailing 'a' from '${src_array}'),'\_%')
OR dataset.name LIKE concat(trim(trailing 'b' from '${src_array}'),'\_%')
OR dataset.name LIKE '${src_array}%'
Still have to believe there is a better way though.
- Scott
