OpenStack Discussions
Cinder fails to create volume with eseries OpenStack icehouse
JULIANDIAZ
Hello!
I'm trying to integrate our new E5524 in one of our test clouds and I keep running against an error when I try to create a volume using cinder (ver: 1.0.8). I have already installed the Proxy as stated in the document: https://library.netapp.com/ecm/ecm_get_file/ECMP1506075
This is my cinder.conf file:
[DEFAULT]
enabled_backends=iscsi_emc_vmax_1,NetApp_ESeries
rootwrap_config = /etc/cinder/rootwrap.conf
api_paste_config = /etc/cinder/api-paste.ini
iscsi_helper = tgtadm
volume_name_template = volume-%s
volume_group = cinder-volumes
verbose = True
debug = True
auth_strategy = keystone
state_path = /var/lib/cinder
lock_path = /var/lock/cinder
volumes_dir = /var/lib/cinder/volumes
osapi_volume_workers = 6
rpc_backend = cinder.openstack.common.rpc.impl_kombu
rabbit_host = xxx.xxx.xxx.xxx
rabbit_port = 5672
rabbit_userid = guest
rabbit_password = guest
notification_driver=cinder.openstack.common.notifier.rpc_notifier
periodic_interval=60
report_interval=60
osapi_volume_extension=cinder.api.contrib.standard_extensions
my_ip=xxx.xxx.xxx.xxx
[database]
connection = mysql://cinder:cinder@localhost/cinder
[keystone_authtoken]
auth_uri = http://xxx.xxx.xxx.xxx:5000
auth_host = xxx.xxx.xxx.xxx
auth_port = 35357
auth_protocol = http
admin_tenant_name = service
admin_user = cinder
admin_password = xxxxxxxx
[iscsi_emc_vmax_1]
volume_backend_name=emc_vmax_1
iscsi_target_prefix=iqn.1992-04.com.emc
# ALTERNATIVE PORT --> iscsi_ip_address=xxx.xxx.xxx.xxx
volume_driver=cinder.volume.drivers.emc.emc_smis_iscsi.EMCSMISISCSIDriver
cinder_emc_config_file=/etc/cinder/cinder_emc_vmax_1.xml
[NetApp_ESeries]
volume_driver=cinder.volume.drivers.netapp.common.NetAppDriver
netapp_storage_family=eseries
netapp_storage_protocol=iscsi
netapp_server_hostname=netapp-proxy.despexds.net
netapp_transport_type=http
netapp_webservice_path=/devmgr/v2
netapp_server_port=8080
netapp_login=rw
netapp_password=rw
netapp_controller_ips=10.1.5.22,10.1.5.23
netapp_sa_password=*********
netapp_storage_pools=Disk_Pool_1,Disk_Pool_2
These are the commands I issued to create the backend type:
# cinder type-create NetApp_ESeries
# cinder type-key NetApp_ESeries set volume_backend_name=NetApp_ESeries
# ./restart_all.sh
And to create the test volume:
# cinder create --volume-type NetApp_ESeries --display_name nettest 5
The cinder list shows the error codition associated to the newly created volume:
|                  ID                                        |   Status  | Display Name | Size |  Volume Type      | Bootable |         Attached to             |
| 5d7e7ea6-27c9-412e-beb5-b59b5c105da2 |     error   |      nettest       |  5    | NetApp_ESeries  |  false      |                                      |
This is the output of some information commands:
# cinder type-list
|                              ID                                   |                      Name                 |
| 9b78963c-cfa6-4dc3-8d85-d1bd2f6b5446       |              iscsiEmcVmax1          |
| dad8851f-c8bf-4c0c-88a1-d337a29e8508        |              NetApp_ESeries         |
# cinder extra-specs-list
|                                   ID                                    |             Name         |                            extra_specs                            |
| 9b78963c-cfa6-4dc3-8d85-d1bd2f6b5446             | iscsiEmcVmax1      |   {u'volume_backend_name': u'emc_vmax_1'}   |
| dad8851f-c8bf-4c0c-88a1-d337a29e8508              | NetApp_ESeries     | {u'volume_backend_name': u'NetApp_ESeries'}|
The scheduler log shows the following, I highlighted what caught my attention):
2014-08-08 11:08:51.827 12632 DEBUG oslo.messaging._drivers.amqpdriver [-] received {u'_context_domain': None, u'_context_request_id': u'req-28594cd1-7285-4049-baa6-faaa81653409', u'_context_quota_class': None, u'_context_service_catalog': [{u'endpoints': [{u'adminURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83', u'region': u'RegionOne', u'internalURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83', u'id': u'302b287bedf54a6fa1dd51a73793ee57', u'publicURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83'}], u'endpoints_links': [], u'type': u'compute', u'name': u'nova'}], u'_context_auth_token': '<SANITIZED>', u'_context_user': u'790e3caa38984fccb158b05571e1bc6c', u'_context_user_id': u'790e3caa38984fccb158b05571e1bc6c', u'_context_is_admin': True, u'version': u'1.2', u'_context_project_domain': None, u'_context_timestamp': u'2014-08-08T15:08:51.274902', u'method': u'create_volume', u'_context_remote_address': u'10.111.81.20', u'_context_roles': [u'KeystoneAdmin', u'KeystoneServiceAdmin', u'admin'], u'args': {u'request_spec': {u'volume_properties': {u'status': u'creating', u'volume_type_id': u'dad8851f-c8bf-4c0c-88a1-d337a29e8508', u'user_id': u'790e3caa38984fccb158b05571e1bc6c', u'availability_zone': u'nova', u'reservations': [u'1236dfef-ea96-4dd2-b196-6a397e22d974', u'8c0cfc24-9188-4592-8dfa-9760fd5171e1', u'65d8f43d-a17b-4088-bd12-3ab9887cce92', u'8f6cda2f-300f-4e94-88c9-fde4ba53679f'], u'snapshot_id': None, u'attach_status': u'detached', u'display_description': None, u'volume_metadata': [], u'encryption_key_id': None, u'source_volid': None, u'volume_admin_metadata': [], u'display_name': u'nettest', u'project_id': u'3ab47e19d21c4672973e57e7a8c85c83', u'id': u'5d7e7ea6-27c9-412e-beb5-b59b5c105da2', u'size': 5, u'metadata': {}}, u'volume_type': {u'name': u'NetApp_ESeries', u'qos_specs_id': None, u'deleted': False, u'created_at': u'2014-08-08T14:17:56.000000', u'updated_at': None, u'extra_specs': {u'volume_backend_name': u'NetApp_ESeries'}, u'deleted_at': None, u'id': u'dad8851f-c8bf-4c0c-88a1-d337a29e8508'}, u'image_id': None, u'snapshot_id': None, u'source_volid': None, u'volume_id': u'5d7e7ea6-27c9-412e-beb5-b59b5c105da2'}, u'volume_id': u'5d7e7ea6-27c9-412e-beb5-b59b5c105da2', u'filter_properties': {}, u'topic': u'cinder-volume', u'image_id': None, u'snapshot_id': None}, u'_unique_id': u'cd189dbaada94d98ab458439cb818b62', u'_context_project_name': u'admin', u'_context_read_deleted': u'no', u'_context_user_identity': u'790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -', u'_context_tenant': u'3ab47e19d21c4672973e57e7a8c85c83', u'_context_project_id': u'3ab47e19d21c4672973e57e7a8c85c83', u'_context_user_domain': None} _safe_log /usr/lib/python2.7/dist-packages/oslo/messaging/_drivers/common.py:290
2014-08-08 11:08:51.829 12632 DEBUG oslo.messaging._drivers.amqp [-] unpacked context: {'tenant': u'3ab47e19d21c4672973e57e7a8c85c83', 'domain': None, 'project_name': u'admin', 'user_id': u'790e3caa38984fccb158b05571e1bc6c', 'roles': [u'KeystoneAdmin', u'KeystoneServiceAdmin', u'admin'], 'user_identity': u'790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -', 'project_domain': None, 'timestamp': u'2014-08-08T15:08:51.274902', 'auth_token': '<SANITIZED>', 'remote_address': u'10.111.81.20', 'quota_class': None, 'user_domain': None, 'is_admin': True, 'user': u'790e3caa38984fccb158b05571e1bc6c', 'service_catalog': [{u'endpoints_links': [], u'endpoints': [{u'adminURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83', u'region': u'RegionOne', u'publicURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83', u'internalURL': u'http://10.111.81.1:8774/v2/3ab47e19d21c4672973e57e7a8c85c83', u'id': u'302b287bedf54a6fa1dd51a73793ee57'}], u'type': u'compute', u'name': u'nova'}], 'request_id': u'req-28594cd1-7285-4049-baa6-faaa81653409', 'project_id': u'3ab47e19d21c4672973e57e7a8c85c83', 'read_deleted': u'no'} _safe_log /usr/lib/python2.7/dist-packages/oslo/messaging/_drivers/common.py:290
2014-08-08 11:08:51.833 12632 WARNING cinder.context [-] Arguments dropped when creating context: {'user': u'790e3caa38984fccb158b05571e1bc6c', 'tenant': u'3ab47e19d21c4672973e57e7a8c85c83', 'user_identity': u'790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -'}
2014-08-08 11:08:51.833 12632 DEBUG stevedore.extension [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] found extension EntryPoint.parse('default = taskflow.engines.action_engine.engine:SingleThreadedActionEngine') _load_plugins /usr/lib/python2.7/dist-packages/stevedore/extension.py:156
2014-08-08 11:08:51.834 12632 DEBUG stevedore.extension [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] found extension EntryPoint.parse('serial = taskflow.engines.action_engine.engine:SingleThreadedActionEngine') _load_plugins /usr/lib/python2.7/dist-packages/stevedore/extension.py:156
2014-08-08 11:08:51.834 12632 DEBUG stevedore.extension [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] found extension EntryPoint.parse('parallel = taskflow.engines.action_engine.engine:MultiThreadedActionEngine') _load_plugins /usr/lib/python2.7/dist-packages/stevedore/extension.py:156
2014-08-08 11:08:51.835 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.save_both' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.835 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.835 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Starting to flatten 'taskflow.patterns.linear_flow.Flow: volume_create_scheduler; 2' _pre_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:154
2014-08-08 11:08:51.836 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Starting to flatten 'cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0' _pre_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:154
2014-08-08 11:08:51.836 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Finished flattening 'cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0' _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:159
2014-08-08 11:08:51.837 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Translated 'cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0' into a graph: _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:164
2014-08-08 11:08:51.837 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Name: cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.837 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Type: DiGraph _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.838 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Frozen: False _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.838 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Nodes: 1 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.838 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]    - cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.839 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Edges: 0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.839 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Density: 0.000 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.839 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Cycles: 0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.840 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Starting to flatten 'cinder.scheduler.flows.create_volume.schedule_create_volume==1.0' _pre_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:154
2014-08-08 11:08:51.840 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Finished flattening 'cinder.scheduler.flows.create_volume.schedule_create_volume==1.0' _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:159
2014-08-08 11:08:51.841 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Translated 'cinder.scheduler.flows.create_volume.schedule_create_volume==1.0' into a graph: _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:164
2014-08-08 11:08:51.841 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Name: cinder.scheduler.flows.create_volume.schedule_create_volume _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.841 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Type: DiGraph _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.842 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Frozen: False _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.842 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Nodes: 1 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.842 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]    - cinder.scheduler.flows.create_volume.schedule_create_volume==1.0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.843 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Edges: 0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.843 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Density: 0.000 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.843 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Cycles: 0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.844 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Finished flattening 'taskflow.patterns.linear_flow.Flow: volume_create_scheduler; 2' _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:159
2014-08-08 11:08:51.844 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Translated 'taskflow.patterns.linear_flow.Flow: volume_create_scheduler; 2' into a graph: _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:164
2014-08-08 11:08:51.845 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Name: volume_create_scheduler _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.845 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Type: DiGraph _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.845 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Frozen: False _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.845 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Nodes: 2 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.846 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]    - cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.846 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]    - cinder.scheduler.flows.create_volume.schedule_create_volume==1.0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.846 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Edges: 1 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.847 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]    cinder.scheduler.flows.create_volume.ExtractSchedulerSpecTask;volume:create==1.0 -> cinder.scheduler.flows.create_volume.schedule_create_volume==1.0 ({'flatten': True}) _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.847 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Density: 0.500 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.847 12632 DEBUG taskflow.utils.flow_utils [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -]  Cycles: 0 _post_item_flatten /usr/lib/python2.7/dist-packages/taskflow/utils/flow_utils.py:167
2014-08-08 11:08:51.848 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.save_both' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.849 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.save_both' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.850 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_flow_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.850 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.851 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.852 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.857 12632 WARNING cinder.scheduler.host_manager [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] volume service is down or disabled. (host: cinder-dev01@ceph)
2014-08-08 11:08:51.857 12632 WARNING cinder.scheduler.host_manager [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] volume service is down or disabled. (host: cinder-dev01@e5524iscsi)
2014-08-08 11:08:51.858 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] extra_spec requirement 'NetApp_ESeries' does not match '3250vs1' _satisfies_extra_specs /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:55
2014-08-08 11:08:51.858 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] host 'cinder-dev01@3250direct1': free_capacity_gb: 149 fails resource_type extra_specs requirements host_passes /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:68
2014-08-08 11:08:51.859 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] extra_spec requirement 'NetApp_ESeries' does not match 'emc_vmax_1' _satisfies_extra_specs /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:55
2014-08-08 11:08:51.859 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] host 'cinder-dev01@iscsi_emc_vmax_1': free_capacity_gb: unknown fails resource_type extra_specs requirements host_passes /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:68
2014-08-08 11:08:51.860 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] extra_spec requirement 'NetApp_ESeries' does not match '3250vs3' _satisfies_extra_specs /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:55
2014-08-08 11:08:51.860 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] host 'cinder-dev01@3250direct3': free_capacity_gb: 399 fails resource_type extra_specs requirements host_passes /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:68
2014-08-08 11:08:51.861 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] extra_spec requirement 'NetApp_ESeries' does not match '3250vs2' _satisfies_extra_specs /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:55
2014-08-08 11:08:51.861 12632 DEBUG cinder.openstack.common.scheduler.filters.capabilities_filter [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] host 'cinder-dev01@3250direct2': free_capacity_gb: 377 fails resource_type extra_specs requirements host_passes /usr/lib/python2.7/dist-packages/cinder/openstack/common/scheduler/filters/capabilities_filter.py:68
2014-08-08 11:08:51.861 12632 DEBUG cinder.scheduler.filter_scheduler [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Filtered [host 'cinder-dev01@NetApp_ESeries': free_capacity_gb: 34276] _get_weighted_candidates /usr/lib/python2.7/dist-packages/cinder/scheduler/filter_scheduler.py:259
2014-08-08 11:08:51.862 12632 DEBUG cinder.scheduler.filter_scheduler [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Choosing cinder-dev01@NetApp_ESeries _choose_top_host /usr/lib/python2.7/dist-packages/cinder/scheduler/filter_scheduler.py:276
2014-08-08 11:08:51.902 12632 DEBUG oslo.messaging._drivers.amqp [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] UNIQUE_ID is 87e50cc925184c788a711fd6c127f493. _add_unique_id /usr/lib/python2.7/dist-packages/oslo/messaging/_drivers/amqp.py:338
2014-08-08 11:08:51.911 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.913 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_task_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.914 12632 DEBUG taskflow.storage [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] No backend provided, not calling functor 'taskflow.storage.SingleThreadedStorage._save_flow_detail' _with_connection /usr/lib/python2.7/dist-packages/taskflow/storage.py:88
2014-08-08 11:08:51.915 12632 DEBUG oslo.messaging._drivers.amqp [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] UNIQUE_ID is 68d7b06ec351464a943e7c4990ed91ae. _add_unique_id /usr/lib/python2.7/dist-packages/oslo/messaging/_drivers/amqp.py:338
2014-08-08 11:08:51.917 12632 DEBUG oslo.messaging._drivers.amqp [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] UNIQUE_ID is 995a17dcfb63479098cf05b9901f0768. _add_unique_id /usr/lib/python2.7/dist-packages/oslo/messaging/_drivers/amqp.py:338
At the end of the third try it adds:
2014-08-08 11:09:02.085 12632 ERROR cinder.scheduler.flows.create_volume [req-28594cd1-7285-4049-baa6-faaa81653409 790e3caa38984fccb158b05571e1bc6c 3ab47e19d21c4672973e57e7a8c85c83 - - -] Failed to schedule_create_volume: No valid host was found. Exceeded max scheduling attempts 3 for volume None
I have already tried changing the port in the cinder.conf to 80 (I disabled SSL and 8443 port edditing the wsconfig.xml file in the proxy:
<?xml version="1.0" encoding="UTF-8"?>^M
<config version="1">^M
^M
    <port>8080</port>^M
    <workingdir>working</workingdir>^M
    <env-entries>
        <env key="enable-basic-auth">true</env>
    </env-entries>
</config>
I don't know what else to do... Any help will be greatly appreciated.
Thanks in advance!
1 ACCEPTED SOLUTION
JULIANDIAZ
Actually the problem was solved by modifying the cinder.conf, I added this line: volume_backend_name=<name used to define the backend type>
And I also had to remove the Admin password on the storage (via santricity) and remove this line on the cinder.conf: netapp_sa_password=<arrayPassword>
I'm not sure if the password I set using Santricity is the password I should use here because it's very weird that it didn't authenticate with it...
4 REPLIES 4
rcallawa
What does the cinder-volume log say?
JULIANDIAZ
rcallawa
netapp_sa_password is only authenticated when privileged operations are executed (create volume, delete volume, etc).
JULIANDIAZ
Hmmm, that's interesting, do you know if that password is the one that is configured using SANtricity under "Setup"/"Set a storage array password" because as far as I could see there are only 2 users already set up using SANtricity, one is "Administrator" and the other is "Monitor" and the only way I could get it to work is clearing the "Administrator" pwd and errasing the: netapp_sa_password=<arrayPassword> line in cinder.conf
I think there may be another user/pwd somewhere else but I'm not sure...
