OpenStack Discussions
Manila.conf parameter max_over_subscription_ratio
stevenzhang
Hello experts
Is netapp fas support to configuration max_over_subscription_ratio?
The following is my manila.conf ,i find max_over_subscription_ratio not take effect.
One aggr assign to manila, the capacity is 53T, if max_over_subscription_ration=1.5 take effect, the max provision vol size should <  79T (53*1.5)
[DEFAULT]
state_path = /var/lib/manila
my_ip =
host = t7-int-vip
glance_api_servers = http://t7-int-vip:9292
auth_strategy = keystone
#osapi_share_listen = t7-int-vip
osapi_share_listen = $my_ip
osapi_share_listen_port =8786
log_dir = /var/log/manila
transport_url = rabbit://openstack:rabbitmq_pass@t7-int-vip:5672
max_over_subscription_ratio =1.5
osapi_max_limit=1000
default_share_type = default_share_type
share_name_template = share-%s
share_snapshot_name_template = share-snapshot-%s
debug = True
rootwrap_config = /etc/manila/rootwrap.conf
api_paste_confg = /etc/manila/api-paste.ini
enabled_share_backends = svm02_manila
enabled_share_protocols = NFS
#scheduler_driver = manila.scheduler.drivers.filter.FilterScheduler
#osapi_share_extension = manila.api.contrib.standard_extensions
[database]
connection = mysql+pymysql://manila:MANILA_DBPASS@t7-int-vip/manila
[keystone_authtoken]
www_authenticate_uri = http://t7-int-vip:5000
auth_url = http://t7-int-vip:5000
memcached_servers = t7-node-1:11211,t7-node-2:11211,t7-node-3:11211
auth_type = password
project_domain_id = default
user_domain_id = default
project_name = service
username = manila
password = MANILA_DBPASS
[oslo_concurrency]
lock_path = $state_path/tmp
[svm02_manila]
share_backend_name = svm02_manila
share_driver = manila.share.drivers.netapp.common.NetAppDriver
driver_handles_share_servers = False
netapp_storage_family = ontap_cluster
netapp_server_hostname =
netapp_login = admin
netapp_password =
netapp_vserver = svm02_manila
netapp_volume_snapshot_reserve_percent = 5
netapp_aggregate_name_search_pattern = ^aggr.*$
netapp_server_port=80
netapp_transport_type=http
1 REPLY 1
balaramesh
Hi Stevenzhang
the max_over_subscription_ratio is supported by the Manila Driver, but its functionality is implemented as follows:
1. Settting the max_over_subscription_ratio to a value above than 1 (1.5 for example), then it is possible to create multiple manila shares, whose total summation exceeds 1.5 times the total capacity of the available aggregates.
In your case, for a 53TB aggregate and a max_over_subscription_ratio value of 1.5, then there can be multiple shares created, whose total capacity will be permitted to be <79T.
The size of a single share will not exceed 53T.
Also, you can probably get a quicker response by posting on the #openstack channel in our Slack workspace. You can join at netapp.io/slack
