Simulator Discussions
0002-266 Admin error: FlexClone is not licensed on storage system during snap connect command
Carsten_Recknagel
I've configured the snapdrive utility against an DATA SVM in a one node cluster environment because of administration separation issues.
the "snapdrive create" command  runs properly but the "snapdrive connect" command raises the 002-266 Error.
The FlexClone license is installed but it shows the type "Node locked" to the Node SVM Name.
Is this only a simualtor behavior and we can avoid this problem in our future Storage System ?
regards Carsten
0 REPLIES 0
