Simulator Discussions
How to correct mount CIFS volume from linux ??
Wencheng
Hi All
       I am learning NetAPP...and create a CIFS volume..volume name is engineering.
now I could let Win10 mount it and write a file well. (mount path : \\SVM_IP\nsroot\engineering)
then I  want to using linux to mount CIFS volume...
I create a (cifs) file to provide credential information like below
username=plateuser
password=vu/41234
domain=abc.com.tw
then add setting in /etc/fstab
<SVM_IP>:/engineering /mnt/test cifs ro,nouser,noexec,nosuid,credentials=/usr/XXX/yyy/ZZZ/cifs 0 0
but I tested mount..it show BAD UNC...
which parameter or setting that I forgot or set error ?
thanks
Wencheng
3 REPLIES 3
Wencheng
When I try to troubleshooting  mount NetAPP CIFS volume issue..
I think and compare using the same linux (SuSE12 SP4 ) to mount other CIFS volume.
so I try to mount a NAS share volume , this SuSE12SP4 could mount well.
but I try to mount NetAPP CIFS volume it show error (5)
fabio_nowak
I'm getting a similar error after upgrading from 9.5 to 9.7.
I'm able to mount, but after sometime when I try to use the area, I get this message
OSError: [Errno 5] Input/output error:
I try to umount e mount, everything works again, but just for a while.
liu
