Simulator Discussions
Is there any instruction about connecting Trident from ONTAP Simulator?
shypervisor
Hopefully, following points are documented for passing TR-4798 sample.
  • IP Address/Mask/Gateway setting for ONTAP System Manager
  • Required License for ONTAP Simulator (SnapMirror etc)
  • Required SVM configuration
  • Required Aggregation configuration
1 ACCEPTED SOLUTION
darb0505
Hi @shypervisor ,
You should be able to connect Trident to ONTAP simulator.  Here is instructions on configuring ONTAP and connecting it to trident.
Link: ONTAP Configuration for Trident
There is also additional information in that link on how to fully configure Trident.  Also want to mention that you can go to the NetApp Trident github for additional assistance.
Let us know if you have any additional questions.
Thanks
Team NetApp
2 REPLIES 2
darb0505
Hi @shypervisor ,
Thanks
Team NetApp
shypervisor
Thanks for your help. I personally solved by private communication.
