Simulator Discussions
Question about connecting ONTAPSimuator from Trident
shypervisor
Is there any instruction to connect ONTAP Simulator as a Trident Backend?
  (I cannot found detailed documentation about connecting. I guess, The port numbers are written in backend code.)
I am using VMware Player from separated Physical Machine with K8s Master Node (another separated Physical Machine)
1 ACCEPTED SOLUTION
shypervisor
This problem is already solved by private communication.
2 REPLIES 2
shypervisor
Is there any document about written managementLIF and dataLIF default port number?
shypervisor
